Ball bearing
Revision as of 17:47, 11 October 2016 by Funreprap (talk | contribs)
Ball bearing
Vitamin
Ball bearing are used for low friction movements across an axis.
Wikipedia Rolling-element bearing
A ball bearing is a bearing used for low friction movements across an axis. They are cheap and widely available, mostly from the skateboard industry.
Lubrication
Ball bearings are usually closed and have their own lubrication, so no additional lubrication is needed.
Name
The first digit of the model name refers to the kind of bearing, the second digit to its robustness. The third digit is usually the bore size in mm. Then follows the bearing type letters.
Types
There are several types of ball bearings:
Abbrev. Type Notes
Z Shielded, single
ZZ Shielded, double Sufficient for most RepRaps.
RS Sealed, single
2RS Sealed, double For keeping out generated dust and grit (e.g. from a Milling and Drilling Head)
V Non-contact seal, single
VV Non-contact seal, double
DDU Contact seals, double
NR Snap ring and groove
M Brass cage
Sizes
The most common ball bearings are:
Abbrev. Inner D. Outer D. Thickness Notes
608 8 mm 22 mm 7 mm A common roller skate bearing used extensively in RepRaps.
688 8 mm 16 mm 5 mm
686 6 mm 13 mm 5 mm
626 6 mm 19 mm 6 mm
625 5 mm 16 mm 5 mm
624 4 mm 13 mm 5 mm
623 3 mm 10 mm 4 mm
603 3 mm 9 mm 5 mm
633 3 mm 13 mm 5 mm
The 608 size ball bearings in particular are extremely low cost. Their 8 mm bore size almost forces us to mount them on:
They will need shims to fit snugly on threaded rod. Thin aluminum (pop cans) often works.
The 626 size ball bearing have a 6 mm bore size. We can mount them on:
The 624 bearing have a 4 mm bore size. We can mount them on:
The 626 and 624 bearings seem to cost more than 608 bearings, but M6 and M4 bolts and threaded bar cost less than M8 threaded bar and bolts, so it's almost a wash.
Vendors
Vendor From 8 mm 6 mm 5mm 4 mm 3 mm Additional notes
Alfa-Tech3D DK 608RS 608ZZ
626ZZ
625ZZ
624ZZ
623ZZ
From 1 pcs. Delivered Worldwide.
Folger Technologies, LLC US 608Z 626Z 625Z 624Z 623Z Offers various other bearings, high quality, and fast shipping.
3D Acessories Hub India 608z Bearing     624z bearing
Charlie's 3D Technologies BE 608ZZ     624ZZ
ReprapUniverse.com Netherlands 608ZZ     624ZZ   High Quality Miniature Ball Bearings for Reprap 3D Printers. Sells per 1 piece / 10 pcs / 60 pcs - Cheap International Shipping.
RobotDigg CN 608ZZ 626ZZ 625ZZ
625-2RS
624ZZ 623ZZ
FunReprap France FR 608RS
608ZZ
626ZZ 625ZZ 624ZZ 623ZZ
V-623ZZ
603ZZ
Envoi Rapide tous les jours pour toute l'Europe. D'autres references disponibles, Roulements à billes ou linéaire LM6 - 8 - 10 - 12 UU - 16014 etc...
Paoparts FR 608ZZ 626ZZ   624ZZ 623ZZ
603ZZ
Reprapsource DE 608ZZ     624ZZ
RepRap Kits UK 608ZZ     624ZZ
3DMakerWorld US 608ZZ
BOCA Bearings US many many   many many
VXB Ball Bearings US many many   many many
D&D-TOP Bearings CN many many   many many
TaoTac.com VN 608ZZ 626ZZ 625ZZ 624ZZ 623ZZ
Makeralot CN 608ZZ 688ZZ
686ZZ 626ZZ
625ZZ 695ZZ
624ZZ 634ZZ
Shipping worldwide. Also available 6900ZZ 10x22x6mm Ball Bearing, 16014 Ball Bearing, etc.
Technobots UK 608ZZ
more
626ZZ
more
  624ZZ
more
623ZZ
633ZZ
more
RepRap Portugal PT 608Z 626Z 625Z 624Z 623Z Dedicated Portuguese community, we also establish connection between the Portugal local sellers.
CIE Auto Source CN many many   many many
Wholesale Skateboard Bearings US 608SS         Minimum 80 pcs.
Imprimante 3D France FR 608ZZ
608ZZ (10 pcs)
626ZZ
626ZZ (10 pcs)
  624ZZ
624ZZ (10 pcs)
623ZZ Paris area. Also available: MR105ZZ (5-10-4), 6700ZZ, MR126ZZ
chartup.com System Engineering GmbH DE         533Z
DIY-India.com IN 608Z
Aus3d.com.au AU 608ZZ
    624ZZ
  Sell individually or in packs. Fast $2 shipping within Australia for small orders.
Makemendel IN 608
    624
  Sell worldwide.
Think3dPrint3d UK         623ZZ
Sell worldwide.
3DP2GO CN 608ZZ
626ZZ 625ZZ 624ZZ 623ZZ Ship to worldwide.
See also
External Links
