Ball bearing
Revision as of 09:54, 30 May 2013 by Virtlink (talk | contribs)
Ball bearing
Vitamin
Ball bearing are used for low friction movements across an axis.
Wikipedia Rolling-element bearing
A ball bearing is a bearing used for low friction movements across an axis. They are cheap and widely available, mostly from the skateboard industry.
Lubrication
Ball bearings are usually closed and have their own lubrication, so no additional lubrication is needed.
Name
The first digit of the model name refers to the kind of bearing, the second digit to its robustness. The third digit is usually the bore size in mm. Then follows the bearing type letters.
Types
There are several types of ball bearings:
Abbrev. Type Notes
Z Shielded, single
ZZ Shielded, double Sufficient for most RepRaps.
RS Sealed, single
2RS Sealed, double For keeping out generated dust and grit (e.g. from a Milling and Drilling Head)
V Non-contact seal, single
VV Non-contact seal, double
DDU Contact seals, double
NR Snap ring and groove
M Brass cage
Sizes
The most common ball bearings are:
Abbrev. Inner D. Outer D. Thickness Notes
608 8 mm 22 mm 7 mm A common roller skate bearing used extensively in RepRaps.
626 6 mm 19 mm 6 mm
624 4 mm 13 mm 5 mm
623 3 mm 10 mm 4 mm
603 3 mm 9 mm 5 mm
The 608 size ball bearings in particular are extremely low cost. Their 8 mm bore size almost forces us to mount them on:
The 626 size ball bearing have a 6 mm bore size. We can mount them on:
The 624 bearing have a 4 mm bore size. We can mount them on:
The 626 and 624 bearings seem to cost more than 608 bearings, but M6 and M4 bolts and threaded bar cost less than M8 threaded bar and bolts, so it's almost a wash.
Vendors
Vendor From 8 mm 6 mm 4 mm 3 mm Additional notes
Charlie's 3D Technologies BE 608ZZ
Paoparts FR 608ZZ 626ZZ 624ZZ 623ZZ
603ZZ
Reprapsource DE 608ZZ   624ZZ
RepRap Kits UK 608ZZ   624ZZ
3DMakerWorld US 608ZZ
BOCA Bearings US many many many many
VXB Ball Bearings US many many many many
D&D-TOP Bearings CN many many many many
Technobots UK 608ZZ
more
626ZZ
more
624ZZ
more
623ZZ
633ZZ
more
CIE Auto Source CN many many many many
Wholesale Skateboard Bearings US 608SS       Minimum 80 pcs.
Imprimante 3D France FR 608ZZ
608ZZ (10 pcs)
626ZZ
626ZZ (10 pcs)
624ZZ
624ZZ (10 pcs)
623ZZ Paris area.
External Links
