Belts and Pulleys
This page has been flagged as containing duplicate material that GT2_Timing_Belt also attempts to cover.
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
See also Choosing_Belts_and_Pulleys
Belts
See also GT2 Timing Belt
Supplier | From | Type available | Pitch | Width | Length | Material | Additional notes | |
Folger Technologies, LLC | US | GT2 | 2mm | 3mm/6mm/9mm | Meter or Foot | |||
3Distributed | UK | GT2 | 2mm | 6mm | Sold by the metre | Fiberglass reinforced neoprene rubber. | ||
Think3DPrint3D | UK | GT2, T2.5 | 2 mm, 2.5 mm | 6 mm | sold by the meter | fiberglass reinforced rubber, steel-reinforced polyurethane | ||
3D Acessories Hub | India | GT2, T2.5 | 2 mm | 660mm closed | Rubber | polyurethane | ||
3D Printer Czar | US | GT2 | 2 mm | 6 mm | at your choice | Neoprene, fiberglass reinforced | ||
3DCracker | CN | GT2 | 2 mm | 6 mm | 900mm, 976mm, 1220mm, 1350mm | Neoprene, fiberglass reinforced | ||
He3D | CN | GT2, MXL, T2.5, T5 | 2.5 mm | 6 mm | 1350mm 990mm and open ended | Neoprene, fiberglass reinforced | ||
ReprapUniverse.com | Netherlands | T2.5 GT2 |
2.5 mm 2.0 mm |
5 mm 6 mm |
sold by the meter | Open ended Neoprene Rubber with Fiberglass Reinforced | ||
3DMakerWorld | US | GT2 | 2 mm | 6 mm | 1164 mm | Neoprene, fiberglass reinforced | - | |
Alfa-Tech3D | DK | GT2 | 2 mm | 6 mm | open ended, Sold by the meter | Neoprene, reinforced with fiberglass | ||
Charlie's 3D Technologies | Belgium | MXL and GT2 | - | - | - | - | ||
Cubic Print | Germany | T2.5 T5 |
2.5 mm 5 mm |
6 mm | as you wish | PU + steel | open belts | |
BBMan | US | Imperial/Metric | ||||||
Belting Online | UK | GT2, MXL, T2.5, T5 | 2 mm 2.5 & 5mm | As you wish | As you wish | PU & Neoprene Rubber | ||
Easy RepRap | USA | Precision GT2 | 2 mm | 6 mm | 1150mm | Fiberglass Reinforced | ||
eBay: Yellowvirtualsales | USA | Precision GT2 | 2 mm | 6 mm | Cut To Length | Fiberglass Reinforced | ||
Econobelt | US | many | ||||||
Eke | China | many | ||||||
Indiamart | India | many | ||||||
Inventables | US | MXL | - | - | 1 foot increments | - | - | |
KainaBelt | China | many | ||||||
Makemendel | India | GT2 T2.5 |
2mm 2.5 mm |
7 mm 7mm |
Open Belt | PU | ||
Megadyne | Italy | many | ||||||
Misumi | multiple | |||||||
Paoparts | France | T2.5, T5, GT2 | 2,5mm, 5mm, 10mm | 5mm | - | PU | Open and closed | |
PolyBelt | US | T2.5, T5 | 5 mm | 6 mm | - | polyurethane + steel | ||
RepRapWorld | Netherlands | T2.5, T5 | 2,5 mm 5 mm |
5 mm 5 mm |
1 m | neoprene polyurethane + steel |
RobotDigg | China | GT2, MXL, T2.5 | 2 mm | 6mm, 6.35mm or 9mm | 20M or 50M per roll ,Closed-loop GT2 | Neoprene Rubber, Fiberglass Reinforced. MOQ 50M | ||
Royal supply | US | GT2 | 2 mm | 6 mm | 1164 mm | fiberglass / nylon / neoprene | ||
SDP-SI | US | Imperial/Metric | ||||||
TechPaladin | US | GT2 | 2 mm | 5 mm | 1160 mm | neoprene | ||
Tanals | France | many | - | - | - | - | doesn't sell to individuals | |
Thingibox | Spain | GT2 | 2mm | 5 or 6 mm | Sold by the meter, open ended | Neoprene Rubber | ||
TriDPrinting.com | US | GT2 | 2 mm | 6 mm | Sold by the meter, open ended | Neoprene, Fiberglass Reinforced | ||
RepRap-India.com | IN | GT2 | 2 mm | 6 mm | open ended | Neoprene, fiberglass reinforced |
Vendor | Loc. | Product | Width | Pitch | Length | Additional notes |
3Distributed | UK | GT2 Belt | 6mm | 2.00mm | Multiples of 1000mm | |
Think3DPrint3D | UK | GT2 Belt | 6 mm | 2.00 mm | multiples of 1000 mm | |
3D Acessories Hub | IN | GT2 Belt | 7 mm | 2.00 mm | 660 mm | |
3DCracker&RobotDigg | CN | 1524mm Endless GT2 Belt | 6 mm | 2.00 mm | 1524 mm | |
3DCracker | CN | GT2 Belt | 6 mm | 2.00 mm | Open ended and closed-loop | |
3Distributed | UK | Prusa Kit | 6 mm | 2.00 mm | 1000 mm | |
3Distributed | UK | Rostock/Delta Kit | 6 mm | 2.00 mm | 1000 mm | |
3DMakerWorld | US | Belt | 6 mm | 2.00 mm | 1164 mm | |
Alfa-Tech3D | DK | GT2 Belt | 6 mm | 2.00 mm | open ended, From 1000 mm | Worldwide shipping |
B&B Manufacturing | US | Belt | 3, 6, 9 mm | 2.00 mm | 54-1910 mm | |
Beltingonline | UK | Separate Belt at 900mm length | 6 mm | 2.00 mm | various | |
Charlie's 3D Technologies | BE | Belt | 6 mm | 2.03 mm | 1000 mm | |
Cubic-Print | DE | GT2 Belt kit | 6 mm | 2.00 mm | cut to length | |
eBay: fabster3d | CN | Belt | 6 mm | 974-1164 mm | ||
eBay: yellowvirtualsales | US | Precision GT2 Belt | 6 mm | 2.00 mm | Cut To Length | |
EmotionTech | FR | Belt | 6 mm | 2.00 mm | 850 mm | |
Fabberworld | CH | Belt | 6 mm | 2.00 mm | 1000+ mm | |
Gadgets 3D | PL | Kit for RepRap Prusa 2 | 6 mm | 976 mm x 3 | ||
Gadgets 3D | PL | Kit for Rostock Mini | 6 mm | 900 mm x 3 | ||
Makemendel | IN | GT2 Belt | 7 mm | 2.00 mm | 1000 mm and more | |
Misumi | US | 2GT Belt | 4, 6, 9 mm | 2.00 mm | 662-9942 mm | |
Paoparts | FR | 2GT Belt | 6 mm | 2.00 mm | 1000-50000 mm | |
ReprapWorld.com | EU | [1] | 6 mm | 2.00 mm | 1000-75000 mm | |
RobotDigg | CN | GT2 Belt Open Ended, MXL Belt | 6 mm | 2.00 mm | 1000-50000 mm | |
RoyalSupply | US | Belt | 6 mm | 2.00 mm | 1164 mm | |
TechPaladin Printing | US | Belt | 6 mm | 2.00 mm | 1380 mm | |
Thingibox | ES | GT2 Belt | 5 or 6 mm | 2.00 mm | Multiples of 1m | |
TriDPrinting.com | US | GT2 Belt Open Ended | 6 mm | 2.00 mm | 1000-50000 mm | |
Ultibots | US | Belt | 6 mm | 2.00 mm | 1164 mm |
There is also some on ebay.
- beside GT2 belts, there is also 2M that have a 2mm round pitch (like [2] and many other suppliers)
Pulleys
See also GT2 Timing Belt.
Supplier | From | Type available | Pitch | Tooth | Size (bore, OD,...) | Max belt width | Material | Additional notes |
3D Acessories Hub | India | GT2 | 2mm | 20 | 5mm | 6mm | Aluminium with grub screws | |
3Distributed | UK | GT2 | 2mm | 20 | 5mm | 6mm | Aluminium with grub screws | |
Think3DPrint3D | UK | T2.5 | 2.5 mm | 16 | 5 mm | 7 mm | Aluminum with zinc plated steel flanges | |
3DCracker&RobotDigg | CN | GT2 | 2 mm | 16, 20, 36 | 5 mm or 8mm | 7 mm | All Aluminum | |
3DMakerWorld | US | GT2 | 2 mm | 20 & 36 | 5 mm | 6 mm | Aluminium & Polycarbonate with brass insert | |
Alfa-Tech3D | DK | GT2 | 2 mm | 20 | 5 mm | 6 mm | Aluminum + 3 x M4 grub screws | |
ReprapUniverse.com | Netherlands | T2.5, GT2 | 2.5mm, 2 mm | 16, 20 | 5 mm | 6 mm | Aluminum + M3 grub screws | |
Charlie's 3D Technologies | Belgium | MXL and GT2 | - | 15 or 20 | - | - | - | |
2.5mm 5 mm |
8, 16 | 5 mm | 7 mm | alu + steel grub screws | |
BBMan | US | many | ||||||
Belting Online | UK | GT2, T2.5, T5 & MXL | 2mm, 2.5mm, 2.03mm & 5mm | 16, 18, 20, 36 Also Special Made to order if required |
5mm, special sizes are possible. | 6mm | Alu + Grub Screws | |
eBay: Yellowvirtualsales | USA | GT2, HDT3M | 2MM / 3MM | 12-36 | 5 mm | 6-10MM mm | Fiberglass Reinforced | |
Inventables | US | MXL | - | - | - | - | - | |
[3] | India | GT2 T2.5 |
2 2.5 mm |
20 12 or 16 |
5 mm | 7mm | Aluminium with grub screws | T2.5 pulley is available in 12 teeth and 16 teeth as well. |
Paoparts | France | T2,5 T5 GT2 |
2.5mm, 5 mm, 2mm | 16 8 20 |
inner diameter 5mm | Alu | ||
RepRapWorld | Netherlands | T5 | 5 mm | 8 | 5 mm x 17 mm x 20 mm | ? | Alu | Pulley profile has play resulting in lash when reversing |
RobotDigg | China | GT2, T2.5 and MXL | 2mm, 2.5mm, 2.03mm | 16, 18, 20, 36 | 5*17.5*18 mm | 7mm | Alu | |
Royal Supply | US | GT2 | 2 mm | 18 | 4,7 mm | 6 mm | Alu | you'll need to redrill the bore (3/16") to fit usual 5 mm motor shaft |
SDP-SI | US | many | ||||||
TechPaladin | US | GT2 | 2 mm | 36 | 5 mm | 6 mm | plastic/bronze | - |
TriDPrinting.com | US | GT2 | 2 mm | 16, 20 | 5 mm | 6 mm | Aluminium with grub screws | Uses two set screws |
Thingibox | Spain | GT2 | 2 mm | 16, 20 | 5 mm | 4-6 mm | Aluminium + grub screws | |
Ultimachine | US | GT2 | 2 mm | 20 | 5 mm | 6 mm | Alu | use two set screws |
RepRap-India.com | US | GT2, T2.5 | 2 mm | 20 | 5 mm | 6 mm | Alu | use two set screws |
Vendor | Loc. | Product | Material | Belt width | Bore | Tooth | Flange | Additional notes |
3D Acessories Hub | IN | GT2 Pulley | Aluminium | 7 mm | 5.00 mm | 20 | - | |
3DCracker | CN | GT2 Pulley | 7 mm | 5, 8mm | 16, 20, 36 | double | ||
eBay: Yellowvirtualsales | US | Timing Pulleys | Aluminum, Metal | 6mm - 10mm | 5.00 mm | 12-36 | Vary | |
3Distributed | UK | Pulley | 7 mm | 5.00 mm | 20 | double | ||
3DMakerWorld | US | GT2 Timing Pulley | Aluminium & Polycarbonate with brass insert | 6 mm | 5.00 mm | 20 & 36 | double | |
Alfa-Tech3D | DK | GT2 Timing Pulley | Aluminium | 3 mm | 5.00 mm | 20 | double | With 3 x M4 grub screws |
B&B Manufacturing | US | Pulley | Aluminium | 3, 6, 9 mm | 5.00 mm | 12-20 | double | |
Beltingonline | UK | Separate Timing Pulley (sold each) | Aluminium | 6 mm | 5.00 mm | 20 | double | |
Beltingonline | UK | Kits for 3D Printers | Aluminium | 5.00 mm | 20 | double | ||
Charlie's 3D Technologies | BE | Pulley | Aluminium, nylon | 7 mm | 5.00 mm | 20 | double | |
Cubic-Print | DE | Pulley / Kit | Aluminium | 7 mm | 5.00 mm | 20 | double | |
eBay: fabster3d | CN | Pulley | Aluminium (black) | 7 mm | 5.00 mm | 20 | double | |
EmotionTech | FR | Pulley | Aluminium | 6 mm | 5.00 mm | 20 | double | |
Fabberworld | CH | Pulley | Aluminium | 6 mm | 5.00 mm | 20 | double | |
Gadgets 3D | PL | Kit for RepRap | Aluminium (black) | 6 mm | 5.00 mm | 20 | double | |
Makemendel | IN | GT2 Pulley | Aluminium | 7 mm | 5.00 mm | 20 | - | |
Misumi | Japan | Misumi's pulley introduction | ? | ? | ? | ? | ? | Their website does not make it easy to browse for belts and pulleys, but here are the relevent pages in their catalog:
Misumi calls theirs 2GT (2mm pitch) and 3GT (3mm pitch). As far as I know they are compatible with GT2, but both offer the same benefits. |
Paoparts | France | GT2 | aluminium | 6 - 10 mm | 5 mm | multiple | double | |
ReprapWorld.com | EU | Multiple types of Pulley | Aluminium | 5-6 mm | 5mm | Multiple | double | |
Robotdigg | CN | 16Teeth 2GT Pulley | Aluminium | 7 mm | 5mm, 8mm | 16, 20, 36 | double | |
RoyalSupply | US | Pulley | Aluminium | 4-6 mm | 4.76 mm | 18 | double | You'll need to redrill them to fit on the usual 5mm motor shaft |
Stock Drive Products | US | https://sdp-si.com/ | 5.00 mm | 36, 40, 42 | ||||
TechPaladin Printing | US | Pulley | Aluminium | 6 mm | 5.00 mm | 20 | double | |
Thingibox | ES | GT2 Pulley | Aluminium | 4-6 mm | 5.00 mm | 16 | double | |
TriDPrinting.com | US | GT2 Pulley | Aluminium | 6 mm | 5.00 mm | 16, 20 | double | |
Ultibots | US | Pulley | Aluminium | 6 mm | 5.00 mm | 20 | double | |
UltiMachine | US | Pulley | Aluminium | 6 mm | 5.00 mm | 20 | double |
