Buckrap Hot End Bow
Revision as of 06:47, 14 December 2011 by KalleP (talk | contribs) (Improved english translation)
Buckrap Hot End
Buckrap Hot End
Buckrap's Hot End
Here is a simple design Hot End.
200x
Parts
200x
Total costs under EUR15 / US$20:
  • PTFE Tube 6mm (external diameter) 30-50 cm
  • Brass nozzle 0.5mm extruder and M6 (purchased @ Camiel)
  • M6 nut
  • M6 brass coupling tube (photo)
  • Nicrome wire
  • Thermistor
  • Perforated assembly strap 6mm holes (in the lower-right corner of the parts picture)
  • Kapton tape 5mm (and optionally 10mm)
  • Crimp on terminals 1mm
  • Wire
Tools
  • Pliers
  • Wirecutter
  • Crimping tool for terminals
  • Scissors
  • Spanner 10mm for M6 nut
  • Multimeter
Step 1
200x
  • First push the M6 nut on PTFE tube and use the spanner turn it about 2 cm along tube. Then turn back the nut and remove it.
  • Turn the tube into to coupling
  • Turn the brass nozzle into the coupling
Step 2
200x
  • Tape the coupling and the brass nozzle with the Kapton tape
  • Wind the Nicrome wire (Length about 28cm and check for about 6Ohm resistance)
  • Tape over the Nicrome wires to hold in place
Step 3
200x
  • Insulate the thermistor leads with Kapton tape
Step 4
200x
Take attention here
  • Strip insulation from 2 wires for 7cm
  • Strip insulation from 2 wires for 4cm
  • Crimp the long ends to the Nicrome heater wire
  • Cimp the short ends the termistor leads
  • Insulate all wires individually with more Kapton tape
Step 5
200x
  • Tape the wires together and then tape them to the coupling
  • Isulate the top of the coupling (thermal insulation)
Step 6
200x
  • Use perforated assembly strap for mounting there are no forces to contend with but it must not vibrate (Makerbot platform illustrated here)
