Builders/pyRepRap
Revision as of 06:34, 11 January 2015 by Glenn (talk | contribs) (catchg)
Introduction
  • pyRepRap is a Python library for controlling a serial SNAP RepRap.
  • The library supports the full SNAP v1 specification including Cartesian robot and thermoplast extruder.
  • SNAP v2 support will be added as soon as I get my hands on a Arduino / Sanguino.
Download & Install
SVN Path : https://reprap.svn.sourceforge.net/svnroot/reprap/trunk/users/stef/pyRepRap/
Linux
TODO : List Dependencies
svn checkout https://reprap.svn.sourceforge.net/svnroot/reprap/trunk/users/stef/pyRepRap/
cd pyRepRap
python setup.py build
sudo python setup.py install
Windows
I have used this in Windows and it works fine. I need to add the dependencies list and some instructions.
Example
This simple example sends the reprap to the home position, moves the x & y axes around a bit, then returns to the home position and powers off the motors. This is available in the 'examples' folder in the svn.
#!/usr/bin/env python
# Import the reprap  modules
import reprap, time
# Initialise serial port, here the first port (0) is used.
reprap.openSerial( 0, 19200, 60 )
# These devices are present in network, will automatically scan in the future.
reprap.cartesian.x.active = True
reprap.cartesian.y.active = True
reprap.cartesian.z.active = True
reprap.extruder.active = True
# Set axies to notify arrivals
reprap.cartesian.x.setNotify()
reprap.cartesian.y.setNotify()
reprap.cartesian.z.setNotify()
# Set stepper speed to 220 (out of 255)
reprap.cartesian.setSpeed(220)
# Set power to 83%
reprap.cartesian.setPower(83)
# The module is now ready to recieve commands #
# Send all axies to home position. Wait until arrival.
reprap.cartesian.homeReset()
# When using seek with no waitArrival = True/False argument, it defaults to true
# Seek to X1000, Y1000
reprap.cartesian.seek( (1000, 1000, None) )
# Pause
time.sleep(2)
# Seek to X500, Y1000
reprap.cartesian.seek( (500, 1000, None) )
time.sleep(2)
# Seek to X1000, Y500
reprap.cartesian.seek( (1000, 500, None) )
time.sleep(2)
# Seek to X100, Y100
reprap.cartesian.seek( (100, 100, None) )
# Shut off power to all motors.
reprap.cartesian.free()
Documentation
See the 'docs' folder in the svn for pyDoc HTML documentation files.
Programs that use pyRepRap
Replath - RepRap Plotting & Toolpath Generator
