CAN AVR
Revision as of 13:41, 25 November 2011 by Glenn (talk | contribs) (+ Category:Principles)
About
CAN ( Controller-area network ) on AVR chipsets. for information about CAN/CANopen stack , go here CANopen. for general information about CAN chipsets and physical topics , go CAN.
ard'ware
Usual Arduino AtmegaXXX have no CAN controller. I see 3 methods to get it :
  1. AVR using SPI/UART/... connecting to a CAN controller like MCP2515 :
  2. Emulate the CAN controller with external interrupt register and threading support :
  3. Use automotive serie of AtMega that have CAN controller
IMHO , the 3rd method is the more efficient.
AtMega automotive serie
  • ATmega16M1
  • ATmega32M1
  • ATmega64M1
  • ATmega32C1
  • ATmega64C1
M serie has one 12-bit High Speed PSC (Power Stage Controller) :
  • Non Overlapping Inverted PWM Output Pins With Flexible Dead-Time
  • Variable PWM duty Cycle and Frequency
  • Synchronous Update of all PWM Registers
  • Auto Stop Function for Emergency Event
supported by avr-libc , it that can be useful.
They have JTAG _AND_ ISP. Using ATmega let us in the arduino community , our tool set and knowledge.
So the more valuable is ATmega64M with 64kb like sanguino but the cheapest could fit needs of most people.
more infos on this atmel products :
see Noduino development
Possible LIN transceiver
share work with others open source projects
OpenServo 2.1 is based on AVR ATmega168 .
