COssel
Revision as of 21:34, 8 February 2014 by Cdaringe (talk | contribs) (BOM)
cOssel
Delta robot 3D printer with extrusion frame
inwork
Overview
cOssel is an iteration of Johann's Kossel. Design intents are equip a dual head end effector and to move the linear rails to an open design. It also uses 20x20 instead of 15x15. All other tweaks are minor. This design otherwise entirely copies Johann's delta-bot intent. Default configuration is setup for Dual Extruders, heated bed, and EE fan.
Non-contact Autoleveling
cOssel attempts to enable a low-power, non-contact autoleveling sensor as an alternative to using a retractable mechanical switch as used in other Rostock/Kossel deltas. This feature is still experimental as most IR sensors have not been proven repeatable, thus is still unfit for use. Video: Infrared Leveling
Assembly
Pre-install nuts for easier extrusion install
The assembly process should take a short weekend to complete. Make sure that you have a standard tool set, including ball-end metric allen keys.
Main Vertical Assembly
Base Connections
Upper Assembly
Carriages
End Effector
End Stops
The following images show the terminal block on the board. I ended up removing the terminal blocks from the boards to reduce interference from the carriage assembly as it approached the Z_MAX home position.
Rod Ends
It is assumed that your push rods have already been cut to size by yourself or a vendor. If not, cut your rods to length.
  1. Place the rod end ball standing vertically on a stable surface.
  2. Place the rod end socket loosely over the ball end ball.
  3. Space a pair of needle nose pliers around the perimeter of the socket.
  4. Press firmly down and click the socket over the ball.
  5. Prepare the epoxy solution.
  6. Apply dab of mixed epoxy onto threaded 4mm dia, 20mm long set screw
  7. Thread set screw into rod end as deep as it will go
  8. Apply another dab of epoxy onto the set screws, this time, more generous
  9. Gently place the set screws into the carbon fiber tube.
  10. Firmly press both opposing rod ends together along the tube axis.
  11. Set rod to try. Ensure that rod ends are parallel with each other.
Filament Delivery
Spool Assy
Extruders
Frame - External
Bed
Wiring
Fan I/O
The RAMPS_1.4 board does not by default have sufficient IO to power three heaters and additional fans for the extruder heaters. Products exist already to serve this need, but I decided to build my own. I added a constant 12V drop for a always-on stepper driver cooling fan (so long as PS-ON is on), and a PWM circuit for a single extruder cooling fan. I shall use only one fan for both extruders.
BOM
The BOM for COssel is large, thus has been collapsed to not overflow the page. Expand the table below for a flat Bill of Material for procurement!
Part Total Qty Vendor Notes Link
2020_cap 16 Misumi Site is designed for commerical customers, but you can still setup an account. You must manually enter the part numbers into a purchase order. [HFC5-2020-HFC5-2020 @Misumi]
2020-134mm 1 Misumi Site is designed for commerical customers, but you can still setup an account. You must manually enter the part numbers into a purchase order. [HFS5-2020-134-HFS5-2020-134 @Misumi]
2020-200mm 3 Misumi Site is designed for commerical customers, but you can still setup an account. You must manually enter the part numbers into a purchase order. [HFS5-2020-200-HFS5-2020-200 @Misumi]
2020-300mm 7 Misumi Site is designed for commerical customers, but you can still setup an account. You must manually enter the part numbers into a purchase order. [HFS5-2020-300-HFS5-2020-300 @Misumi]
2020-371mm 7 Misumi Site is designed for commerical customers, but you can still setup an account. You must manually enter the part numbers into a purchase order. [HFS5-2020-371-HFS5-2020-371 @Misumi]
2020-50mm 2 Misumi Site is designed for commerical customers, but you can still setup an account. You must manually enter the part numbers into a purchase order. [HFS5-2020-50-HFS5-2020-50 @Misumi]
2020-800mm 3 Misumi Site is designed for commerical customers, but you can still setup an account. You must manually enter the part numbers into a purchase order. [HFS5-2020-800-HFS5-2020-800 @Misumi]
bearing_608z 4 Amazon Easily sourced [608z-- @Amazon]
bearing_624z 6 Amazon Easily sourced [624z-- @Amazon]
bed_glass 1 (no vendor data entered) 300mm beds appear to be scare at the moment. Looking into sources. 250mm from TrinityLabs may need to be an interim substitue.
belt_gt2_1700mm 3 OpenBuilds Order by the foot. 304.8 mm / ft! [--- @OpenBuilds]
bracket_heater_sppt_wood 1 Ponoko Wooden piece. Laser cutting files on GitHub & ponoko [--- @Ponoko]
bracket_hot_end_groovemount_dual 1 Ponoko Wooden piece. Laser cutting files on GitHub & ponoko [--- @Ponoko]
bracket_power_supply_stablity_xy 1 Ponoko Wooden piece. Laser cutting files on GitHub & ponoko [--- @Ponoko]
bracket_tee_2020 9 Misumui Site is designed for commerical customers, but you can still setup an account. You must manually enter the part numbers into a purchase order. [HBLFSN5-HBLFSN5 @Misumui]
cable_ribbon_10_conductor_15ft 2 SparkFun Used for bulk-running the opto +V, SIG, & GND to the board. Also used for clean motor runs and I/O to the EE. Note, some have suggested this is too thin of wire gauge. User to decide [--CAB-1064 @SparkFun]
drive_filament_dia 2 RepRap Sources Mk7-like with 8mm bore to be compatible with phidgets geared steppers. [--- @RepRap Sources]
epoxy_two_part 1 Amazon For gluing the rod ends to the carbon tubing [--- @Amazon]
extruder_maker_gear 2 MakerGear Make sure to configure your order for 1.75 barrel. [--- @MakerGear]
fan_40mm_12VDC 2 Amazon Most 40mm 12VDC fans should do the trick [--- @Amazon]
fitting_one_touch_4mm 4 Amazon 5mm thread req'd and 4mm OD tube receptable req'd [KQ2S04-M5A-- @Amazon]
gear_drive_belt_gt2 3 OpenBuilds 20 tooth or less is critical to prevent the belt from hitting the carriage [--- @OpenBuilds]
motor_nema_17 3 Ultimachine [--UMN17MTR @Ultimachine]
motor_nema_17_geared_5.18_1 2 Phidgets [--3317_1 @Phidgets]
nut_extr_m4 79 Misumi Site is designed for commerical customers, but you can still setup an account. You must manually enter the part numbers into a purchase order.
nut_extr_m5 (open_rail_kit_excess) 69 OpenBuilds Do not order directly for hardware. You will have excess from your wheel kits which instead use the eccentric spacer.
nut_m3 35 Fastenal Nylon lock preferred [--- @Fastenal]
nut_m3_jam 13 Fastenal Jam [--- @Fastenal]
nut_m4 8 Fastenal Nylon lock preferred [--- @Fastenal]
open_rail_bearing 24 OpenBuilds Do not order directly for hardware. You will have excess from your wheel kits which instead use the eccentric spacer.
open_rail_nut_m5 14 OpenBuilds Do not order directly for hardware. You will have excess from your wheel kits which instead use the eccentric spacer.
open_rail_scrw_m5_std_wheel_mnt 12 OpenBuilds Do not order directly for hardware. You will have excess from your wheel kits which instead use the eccentric spacer.
open_rail_shim 9 OpenBuilds Do not order directly for hardware. You will have excess from your wheel kits which instead use the eccentric spacer.
open_rail_shim_eccentric 6 OpenBuilds [--- @OpenBuilds]
open_rail_spacer_bearing 12 OpenBuilds Do not order directly for hardware. You will have excess from your wheel kits which instead use the eccentric spacer.
open_rail_wheel_delrin 6 OpenBuilds [--- @OpenBuilds]
open_rail_wheel_sst 6 OpenBuilds [--- @OpenBuilds]
open_rail-700mm 3 OpenBuilds Order the 1000mm's and cut to length [--- @OpenBuilds]
pcb_arduino_mega 1 Ultimachine Note: The RAMPS stack below includes a MEGA 2560. Make sure not to double buy! [--- @Ultimachine]
pcb_fan_extension_board 1 Geeetech [--- @Geeetech]
pcb_heater 1 Ultimachine [--- @Ultimachine]
pcb_opto 3 Ultimachine [--- @Ultimachine]
pcb_RAMPS_stack 1 Ultimachine Single Z, not dual Z configuration. [--- @Ultimachine]
pcb_sd_ramps_extension_board 1 Geeetech [--- @Geeetech]
power_supply 1 Thermaltake ATX PS. Quiet, reliable. [TR2 TR-700-N82E16817153167 @Thermaltake]
rod_carbon_330mm 6 Hobby-Lobby Must be cut to size. 3x 1000 rods will satisfy a std build [--GXT5540 @Hobby-Lobby]
rod_ends 12 Amazon 4mm OD receptable, 3mm thru-hole ball-ends [5347-- @Amazon]
rod_threaded_8mm-271mm 1 Grainger 5/16" rod is ~8mm too. You can buy 5/16" rod at hardware stores (i.e. Home Depot) for a couple of bucks. [--- @Grainger]
rp_base_vertex 3 RP Files on GitHub
rp_block_bed 3 RP Files on GitHub
rp_bracket_axle_spool 3 RP Files on GitHub
rp_bracket_lateral_sppt 4 RP Files on GitHub
rp_bracket_lateral_sppt_mirrored 4 RP Files on GitHub
rp_bracket_pwr_spply_tab 2 RP Files on GitHub
rp_bracket_RAMPS 1 RP Files on GitHub
rp_extruder_join_lower 1 RP Files on GitHub
rp_extruder_join_upper 1 RP Files on GitHub
rp_fan_mount_motor_drivers 1 RP Files on GitHub
rp_flag_carriage 3 RP Files on GitHub
rp_idler 1 RP Files on GitHub
rp_idler_boss_bearing_8mm 2 RP Files on GitHub
rp_idler_mirrored 1 RP Files on GitHub
rp_idler_strut 2 RP Files on GitHub
rp_mount_fan_ee 1 RP Files on GitHub
rp_opto_mount 3 RP Files on GitHub
rp_plate_slider 3 RP Files on GitHub
rp_ram 3 RP Files on GitHub
rp_upper_vertex 3 RP Files on GitHub
scrw_finish_#6 1 Fastenal Thermal switch is not required, but strongly recommended for safety [--- @Fastenal]
scrw_m3_10 8 Fastenal Pan head & SST preferred when applicable.
scrw_m3_12 18 Fastenal Pan head & SST preferred when applicable.
scrw_m3_15 14 Fastenal Pan head & SST preferred when applicable.
scrw_m3_20 17 Fastenal Pan head & SST preferred when applicable.
scrw_m3_25 2 Fastenal Pan head & SST preferred when applicable.
scrw_m3_35 2 Fastenal Pan head & SST preferred when applicable.
scrw_m3_50 4 Fastenal Pan head & SST preferred when applicable.
scrw_m3_set 5 Fastenal Only order this if your timing pulleys and filament drive gear do not come with their own. They nearly always do.
scrw_m4_10 47 Fastenal
scrw_m4_12 12 Fastenal
scrw_m4_15 25 Fastenal
scrw_m4_25 4 Fastenal
scrw_m4_8 22 Fastenal
scrw_m4_set_20 12 Fastenal Rod End Mounts [--- @Fastenal]
scrw_m5_10 (open_rail_kit_excess) 67 OpenBuilds Do not order directly for hardware. Hardware comes kitted with your rail. [--- @OpenBuilds]
spring_m3_extruder 4 Home Depot Only 1x spring kit reqd [--- @Home Depot]
spring_m4 7 Home Depot Only 1x spring kit reqd [--- @Home Depot]
switch_thermal 1 Amazon [Amico KSD301-- @Amazon]
tab_felt 3 (no vendor data entered) This is a thermal barrier between the bed and the bed clamp. Simply household cloth shall suffice.
tubing_4mm_bowden_1000mm 2 MakerShop Any common RepRap 4mm tube shall suffice [--- @MakerShop]
wire_raceway_10in 1 McMaster-Carr The 6'6" is enough for your full build [--7578K73 @McMaster-Carr]
wire_raceway_25in 1 McMaster-Carr The 6'6" is enough for your full build [--7578K73 @McMaster-Carr]
wire_raceway_5in 2 McMaster-Carr The 6'6" is enough for your full build [--7578K73 @McMaster-Carr]
wire_raceway_8in 1 McMaster-Carr The 6'6" is enough for your full build [--7578K73 @McMaster-Carr]
wire_wrap_10ft 1 McMaster-Carr [--7378K41 @McMaster-Carr]
wshr_4mm 8 Fastenal
wshr_m3 69 Fastenal
wshr_m4 115 Fastenal
wshr_m4_fender 6 Fastenal [--- @Fastenal]
Images
