CVS
Revision as of 04:53, 12 October 2005 by SimonMcAuliffe (talk) (version migrated from twiki)
Using CVS
The reprap CVS server is access by SSH with public key authentication to avoid password issues.
SSH Configuration
The server runs on a non-standard port. The easiest way to make ssh use the correct when called from CVS is to add the following lines to your ~/.ssh/config file:
host reprap.voodoo.co.nz port 922
CVS Configuration
Checking out code is accomplished with commands something this:
$ export CVSROOT=:ext:[email protected]:/cvsroot $ export CVS_RSH=ssh $ cvs co reprap
Getting your account set up
The following details are needed:
  • Your IP address, addresses, masks or netblocks. This is so the firewall will let your connections through.
  • Your SSH public key. If you don't already have one, you can create one
    • Issue the command ssh-keygen -t rsa
    • This will create ~/.ssh/id_rsa.pub
  • Send the IP address in an [email to me|mailto:[email protected] email to me] and attach the public key. Please do not send me the private key (~/.ssh/id_rsa).
If it doesn't work
The first thing to try:
$ telnet reprap.voodoo.co.nz 922
You should get a connect and see an ssh server version number. If there is no connection, then the firewall is blocking you. Double check the address.
Next try this:
$ ssh -p 922 [email protected]
It should give you a shell prompt with no prompting for a password. [Let me know|mailto:[email protected] Let me know] if it doesn't. It probably means the public key or username is incorrect, or that your public key doesn't match your private key.
