Canadian Suppliers
Belts and Pulleys
- mendelmax
- MixShop
- SDP/SI - "they work fine, but were pretty expensive, the shipping was expensive, and the brokerage fees were expensive too. I'd love to find a Canadian source for MXL belts and pulleys, or anything that would work."
Specific SDP-SI MXL pulleys that work on a Darwin:
Z axis - A 6A16-060DF2508 - 60 tooth 1/4 " bore pulley. Can be tapped out to M8 directly.
useful part numbers A 6R 3-C025 (8 ft required) A 6R 3-185025 (1 required)
Quality Transmission Components 125 Railroad Avenue, Garden City Park, NY 11040-5016 Phone: (516) 437-6700 • Fax: (516) 328-3343
This is the supplier that I found to be the most reasonable as far as prices and shipping. For example the t5 x 840mm is listed as $4.20. They also sell matching aluminum pulleys. Also if purchased online there is no minimum purchase amount.
Electronics
- Makerbot
- Digikey.ca
- Mouser (not really)
- robotshop.ca
- sparkfun.com
- gadgetgangster.com
- alltronics.com/
- active123.com/
- leeselectronic.com/
- spikenzielabs.com/
- creatroninc.com/
- proto-advantage.com/ - Hamilton, Ontario
- canakit.com/
- mixshop
- A2APrinter
"Also, if you need electronics, Makerbot is my favorite, but if they're out Digikey is pretty good. They ship to Canada for $10 if you order from digikey.ca, and no brokerage fees. Mouser sent me 50 pages of customs forms detailing every single resistor, cap and chip I ordered for a Darwin, and the brokerage fees cost almost as much as the parts, so I'd stay away from them if you're in Canada."
Steel
- Metal Supermarket
As for other Canadian suppliers, I found Metal Supermarket usually has stock of 5/16" stainless rod, which works for 8mm smooth rod.
- princessauto.com/ - they are a surplus store so there stock can change allot but they do have allot of good things most of the time.
- Generic Steel Suppliers
Check in the telephone directory under "Steel". Your average construction steel supplier sells quite a bit of steel for prices we consider to be very cheap.
Fasteners
- Fastenal here in Vancouver
- Peavey Mart - good general store though they are more in the smaller cities and towns.
I've been getting M8 threaded rod from Fastenal here in Vancouver; they usually need to order in larger quantities, but it's usually pretty fast. I also get all my metric nuts and bolts there. I'm quite happy that Mendel uses fewer types of bolts, btw - that makes life a bit easier.
Also try: brafasco/CTF, Canadian Tire (although be sure to check the parts are actually what they're labeled as -- I found their inventory a little disorganized), Metal Supermarket, Atlas Machine Tools on Queen, Jacob's Hardware on Queen, and even Home Hardware in a pinch for metal rods.
- MixShop.ca
Motors
- alltronics.com/
- linengineeringstore.com/ - they will take paypal but i think you have to email them the order www.linengineeringstore.com/general/terms_conditions.aspx it is in here.
- mixshop
Filament
- Makerbot
- UltiMachine.com
- MixShop.ca
- A2APrinter
computer parts
- memoryexpress.com/
- ncix.com/
Regionalization
Each RUG should have a page, but that will have to wait.
Montreal
Ottawa
Toronto
- creatroninc.com/
- MixShop.ca
- A2APrinter
Vancouver
- canakit.com/
- MixShop.ca
- A2APrinter
Waterloo
Working Notes
This page may duplicate another page
We should put up a page on the Wiki regarding Canadian suppliers. I had a look at the Builders Wiki, but I wasn't sure exactly where to stick it. There's a section in the Mendel BOM and Mendel Buyers Guide regarding suppliers, but this might be more general than just Mendel parts.
