Cartesio Base
Revision as of 04:07, 25 August 2011 by Jos (talk | contribs) (Assembling the bottom layer)
Cartesio Base
Printed CNC machine
GPL v2
see files
This page is under development
This is the start/base of it all.
Here you can go back to the main Cartesio page.
once finished it should look like this :
Images
Files
Parts List
Qnty device RS stockNr
2 profile 20x40x570mm prebuild
6 profile 20x40x260mm prebuild
2 profile 20x20x440mm prebuild
2 profile 20x20x340mm prebuild
1 profile 20x20x260mm prebuild
4 profile 20x20x200mm prebuild
3 profile 20x20x90mm prebuild
4 level foot 257-8656
41 M6 screw 281-293
Assembly Instructions
Joining 2 profiles togheter
Here is why we choose the Bosch/Rexroth profiles in the first place :
Rather than buying expensive profile holders, we can insert a button head M6 bolt inside the profile.
First screw the M6 bolt in the top of one profile, so the head sticks out about 3mm.
Then slide the head of the screw inside the other profile, to the point where it is alligned with the hole in that other profile.
Now stick your imbus key inside of the hole and secure the M6 bolt
2 profile 20x40x260mm prebuild
4 M6 nut
10 M6 screw 281-293
Adding vertical profiles
Assembling the spindels
Putting the spindles in
Adding remaining profiles
Setup
