Category:Files
Revision as of 06:12, 15 January 2015 by Hari Seldon (talk | contribs) (Created page with "Category:Categories")
Subcategories
This category has the following 4 subcategories, out of 4 total.
Media in category "Files"
The following 200 files are in this category, out of 513 total.
(previous page) (next page)- !HuxleyHallProbe.skp ; 218 KB
- --File-Brass.ogg-- ; 239 KB
- 00str00der InAction med.f4v ; 2.22 MB
- 00str00der mob.m4v ; 2.56 MB
- 01-pvc pipe support a-1.pdf ; 28 KB
- 01-pvc pipe support a.ipt ; 430 KB
- 01-pvc pipe support a.pdf ; 45 KB
- 01-pvc pipe support a.stl ; 603 KB
- 02-pvc pipe support b.idw ; 155 KB
- 02-pvc pipe support b.ipt ; 276 KB
- 02-pvc pipe support b.pdf ; 37 KB
- 02-pvc pipe support b.stl ; 478 KB
- 03-z mount bottom 8mm.ipt ; 238 KB
- 03-z mount bottom 8mm.pdf ; 59 KB
- 03-z mount bottom 8mm.stl ; 199 KB
- 04-z mount top 8mm.ipt ; 216 KB
- 04-z mount top 8mm.pdf ; 48 KB
- 04-z mount top 8mm.stl ; 199 KB
- 05-motormount short.ipt ; 194 KB
- 05-motormount short.pdf ; 41 KB
- 05-motormount short.stl ; 43 KB
- 06-motormount tall.ipt ; 194 KB
- 06-motormount tall.pdf ; 49 KB
- 06-motormount tall.stl ; 42 KB
- 07-drivewheel rod.ipt ; 257 KB
- 07-drivewheel rod.pdf ; 81 KB
- 07-drivewheel rod.stl ; 176 KB
- 08-drivewheel tube.ipt ; 201 KB
- 08-drivewheel tube.pdf ; 82 KB
- 08-drivewheel tube.stl ; 183 KB
- 09-22mm 6805 bearing adaptor.ipt ; 88 KB
- 09-22mm 6805 bearing adaptor.pdf ; 28 KB
- 09-22mm 6805 bearing adaptor.stl ; 61 KB
- 1-4in Wood.pdf ; 25 KB
- 1-4inLaserCutSheet.zip ; 90 KB
- 1-8in Metals.pdf ; 7 KB
- 1-8inLaserCutSheet.zip ; 32 KB
- 10-bed arm left 8mm.ipt ; 206 KB
- 10-bed arm left 8mm.pdf ; 34 KB
- 10-bed arm left 8mm.stl ; 152 KB
- 10107 clampnutholder v2.gts ; 36 KB
- 11-bed arm right 8mm.ipt ; 227 KB
- 11-bed arm right 8mm.pdf ; 34 KB
- 11-bed arm right 8mm.stl ; 152 KB
- 12-bed z mount bracket.ipt ; 318 KB
- 12-bed z mount bracket.pdf ; 81 KB
- 12-bed z mount bracket.stl ; 117 KB
- 13-bed rear mountclips.ipt ; 98 KB
- 13-bed rear mountclips.pdf ; 44 KB
- 13-bed rear mountclips.stl ; 27 KB
- 14 (repaired and rotated).stl ; 175 KB
- 14-bed front mountclips.ipt ; 107 KB
- 14-bed front mountclips.pdf ; 33 KB
- 14-bed front mountclips.stl ; 35 KB
- 15-hall endstop holder.ipt ; 180 KB
- 15-hall endstop holder.pdf ; 35 KB
- 15-hall endstop holder.stl ; 63 KB
- 15mm Stahlrohr 440mm.ipt ; 291 KB
- 15mm Stahlrohr 440mm.pdf ; 46 KB
- 15mm steel pipe 200mm.ipt ; 75 KB
- 15mm steel pipe 200mm.pdf ; 27 KB
- 16-leadscrew shaft motor mount.ipt ; 245 KB
- 16-leadscrew shaft motor mount.stl ; 206 KB
- 17-Morgan arm PSI a.ipt ; 225 KB
- 17-Morgan arm PSI a.pdf ; 58 KB
- 17-Morgan arm PSI a.stl ; 108 KB
- 18-Morgan arm PSI b.ipt ; 250 KB
- 18-Morgan arm PSI b.pdf ; 54 KB
- 18-Morgan arm PSI b.stl ; 106 KB
- 19-Morgan arm Theta a.ipt ; 128 KB
- 19-Morgan arm Theta a.pdf ; 41 KB
- 19-Morgan arm Theta a.stl ; 60 KB
- 20-Morgan arm Theta b.ipt ; 131 KB
- 20-Morgan arm Theta b.pdf ; 42 KB
- 20-Morgan arm Theta b.stl ; 52 KB
- 2020.zip ; 18 KB
- 21-Morgan toolhead V3.ipt ; 1.24 MB
- 21-Morgan toolhead V3.pdf ; 93 KB
- 21-Morgan toolhead V3.stl ; 1.96 MB
- 21-Morgan toolhead.ipt ; 449 KB
- 21-Morgan toolhead.pdf ; 90 KB
- 21-Morgan toolhead.stl ; 361 KB
- 22-Leadscrew-nut Alpen8mmSDS.ipt ; 331 KB
- 22-Leadscrew-nut Alpen8mmSDS.pdf ; 34 KB
- 22-Leadscrew-nut Alpen8mmSDS.stl ; 1.23 MB
- 22mm Stahlrohr.ipt ; 69 KB
- 22mm Stahlrohr.pdf ; 25 KB
- 23-extruder bowden adaptor.ipt ; 324 KB
- 23-extruder bowden adaptor.pdf ; 43 KB
- 23-extruder bowden adaptor.stl ; 244 KB
- 24-Morgan Spool holder.ipt ; 175 KB
- 24-Morgan Spool holder.pdf ; 71 KB
- 24-Morgan Spool holder.stl ; 69 KB
- 3-4in Wood.pdf ; 8 KB
- 3-8inLaserCutSheet.zip ; 44 KB
- 311220DAVIDSTJOHN 1.MCX-6 ; 865 KB
- 3D print cost calculator.zip ; 4 KB
- 3D Printer3 featured2.tif 3,872 × 2,592; 344 KB
- 3DragParts.zip ; 1.73 MB
- 4-axis Board fixes from CNCZone.pdf ; 1.44 MB
- 40mm fan bracket.STL ; 55 KB
- 58742 R2 ONYX 27-DEC-2012.zip ; 249 KB
- 68312 CARRIAGE BEARING PLATE.zip ; 14 KB
- 68399 ROSTOCK MAX ACRYLIC0250 JAN 13.zip ; 3.51 MB
- 7 bearing X carriage.stl ; 651 KB
- 7 bearing X carriage.stp ; 25 KB
- 71501 60deg bar clamp.STL ; 143 KB
- 71506 Y Axis Motor Mount.STL ; 368 KB
- 71508 Bar Clamp 90 Degree.STL ; 493 KB
- 71514 Triple Bearing Support.STL ; 121 KB
- 71516 Triple Bearing Cover.STL ; 716 KB
- 71517 Double Bearing Support.STL ; 62 KB
- 71518 Double Bearing Cover.STL ; 61 KB
- 71519 Combo Bearing Cover.STL ; 731 KB
- 71523 Offset Support Rod.STL ; 42 KB
- 71529 Table.STL ; 1.61 MB
- 71531 Z Axis Bearing Plate.STL ; 1,020 KB
- 71532 X Axis Motor Mount.STL ; 1.91 MB
- 71547 Heater Head.STL ; 69 KB
- 71548 Heater Clamp.STL ; 85 KB
- 71550 Mini Extruder Drive.STL ; 293 KB
- 71551 Filament Guide.STL ; 603 KB
- 71552 Extruder Nozzle 0050mm.STL ; 207 KB
- 71554 Extruder Nozzle Mount.STL ; 73 KB
- 71555 Extruder Base.STL ; 1.21 MB
- 71556 Feed Tube Insulator.STL ; 28 KB
- 71559 Extruder Motor Mount.STL ; 459 KB
- 71560 Drive Idler Left.STL ; 436 KB
- 71561 Drive Idler Right.STL ; 434 KB
- 71562 Gear 10T 0500PD.STL ; 139 KB
- 71564 Drive Mount.STL ; 350 KB
- 71565 Gear 28T 1850PD.STL ; 348 KB
- 71566 Gear 15T 0950PD.STL ; 182 KB
- 71569 Gear Combo 15T 28T.STL ; 616 KB
- 71570 Tensioner.STL ; 698 KB
- 71573 Tension Bar.SLDPRT.STL ; 114 KB
- 71576 Z Axis Carriage Assembly.pdf ; 112 KB
- 71581 Rear Base Sub Assembly.pdf ; 82 KB
- 71582 Z Axis Base Sub Assembly.pdf ; 137 KB
- 71583 Frame Assembly.pdf ; 193 KB
- 71584 Y Axis and Z Axis Assembl.pdf ; 284 KB
- 71590 Steves Extruder Assembly.pdf ; 169 KB
- 71622YAxisBeltClamp BETA.stl ; 129 KB
- A History of RepRap Development.epub.zip ; 37.79 MB
- A History of RepRap Development.pdf ; 40.45 MB
- A3979breakout.zip ; 49 KB
- A4 bed drawing.pdf ; 14 KB
- A4 beltSpliterorg.pdf ; 4 KB
- A4 beltSplitterorg.pdf ; 5 KB
- A4 Page.blend ; 161 KB
- A4988 G3D driver rev0.rar ; 19 KB
- A5 beltSplitterorg.pdf ; 5 KB
- Abp bed.zip ; 527 bytes
- AbpTheoryOfOperation.doc ; 26 KB
- Acople cadeneta Eje X.zip ; 83 KB
- ActionCar.zip ; 213 KB
- Adaptacion Husillos.zip ; 685 KB
- Adze-Bronwyn Holloway-Smith.aoi ; 94 KB
- Adze-Bronwyn Holloway-Smith.stl ; 466 KB
- Agit v01.zip ; 150 KB
- Al dily 02.pdf ; 19 KB
- Allinone-motherboard.DXF ; 146 KB
- Allinone-motherboard.EPS ; 99 KB
- AllTogether RepRapMB-v1.2.1.pdf ; 23 KB
- AllTogether USB-TTLv1.2.pdf ; 11 KB
- Alphabrutstruderblock.stl ; 492 KB
- Alphabrutstruderidler.stl ; 104 KB
- AlreadyDoneList-reprap 2005.odp ; 10.13 MB
- Aluminatus Complete.tiff 2,312 × 2,949; 19.51 MB
- Aluminium heatbed support.pdf ; 28 KB
- Anschlussbelegung.pdf ; 84 KB
