Category:UVResin
Revision as of 08:49, 8 September 2013 by KalleP (talk | contribs) (Created page with 'Liquid resin or other polymer curing machines have a different set of mechanical constraints. Often simple with a need for somewhat higher step resolution due to the thinness of…')
Liquid resin or other polymer curing machines have a different set of mechanical constraints. Often simple with a need for somewhat higher step resolution due to the thinness of the cured layer of resin.
They may grow up or down and usually have a single Z axis stage. They may incorporate a mechanical release mechanism and some will have a (galvanometer) scanning system while others will have a image projection system such as a DLP projector.
Resolutions can be higher but consumable costs tend to be higher as well. Build envelopes are typically smaller.
Pages in category "UVResin"
The following 3 pages are in this category, out of 3 total.
