Clog
Revision as of 12:04, 6 March 2015 by Glenn (talk | contribs) (+link)
Clog is what happens when debris develops in the hotend nozzle, or when PLA or ABS plastic gets too hot and hardens in a semi-permanent way, which binds to the nozzle.
Unclogging your nozzle
To clean your extruder follow these steps:
  1. Slacken idler
  2. Push gently on filament while nozzle drops all the way down to room temperature
  3. Re-heat nozzle to Tg (60c for PLA, 105c for ABS)
  4. When it overshoots, pull firmly but slowly. See this or this for an example of a good result
If all else fails, then try a blowtorch as shown here
An alternative for ABS is try and leave your nozzle in acetone for 24-48 hours.
For PLA you can try to use this on your own risk: http://www.makerbot.com/blog/2010/10/19/pla-proven-as-a-dissolveable-support-material/
See also
