Clone wars: Rostock
Revision as of 20:15, 3 March 2013 by Aisflou (talk | contribs) (Bases)
Language Issue/s on this page!
This article needs translation into English.
This article is written in a language other than English. As it is intended for readers from the RepRap community, Alternate translations are encouraged. In particular, an English translation is required. Please see the layout and translations of the http://www.reprap.org/wiki/Main_Page as an example of how this should be achieved. in short you should follow these conventions: If your page is called XXXXX, and is not in english, please do the following:
  • add a languages header to the page, using {{Languages}}
  • copy the non-english content from the "primary" page to the appropriate language page. For example, if your content is in Deutsch, move the content from XXXXX to XXXXX/de
  • revise the original XXXXX page to be english-only, except for the "Languages" header.
Introducción
La Rostock es una impresora de tipo Delta
Piezas imprimibles
Estructura completa
Imagen Pieza (STL) Cantidad Tiempo impresión Comentarios
Idler end rs.jpg idler_end_rs 3 52 min Pieza de idler_end
Carriage rs.jpg carriage_rs 1 1h 1min Pieza de idler_end
Platform rs.jpg platform_rs 3 40 min Pieza de la plataforma
Jaws rs.jpg jaws_rs 12 5 min Pieza de jaws
Solo necesario si no se utiliza las varillas
Joint rs.jpg joint_rs 12 3 min Junta
Rod rs.jpg rod_rs 6 30 min Varillas
Penholder rs.jpg penholder_rs 1 31 min Pieza de penholder
Motor end rs.jpg motor_end_rs 3 1h 34 min Pieza de motor_end
Endstop rs.jpg endstop_rs 3 14 min Pieza del endstop. No son necesarias si solo se utilizan los 3 endstop superiores.
Extrusor
100px [] xx xx xxx
Fotos
Actualizaciones
Vitaminas
Imagen Pieza Cantidad Precio unidad Precio total Tiendas Comentarios
Varillas roscadas
[En construcción] Solo hacen faltan 3 varillas de 8mm. para sujetar las poleas superiores. El tamaño puede ser de 40 o 50 mm. (suficiente para dos tuercas, la polea que es un rodamiento 608 y algunas arandelas) También se pueden usar pernos de 8 mm. Si vas a usar un extrusor airtripper o un jonas es necesario tambien otro trozo de varillas de 20 mm.
Varillas Lisas
[En construcción] 6 barras lisas de 760 mm.
Endstops
[En construcción] 3 Endstops normales son suficientes, se colocan en la parte superior (idler) que lleva dos huecos para los tornillos. Es probable que necesitéis tornillos de metrica 2.5 o incluso 2 para entrar en los endstop. Si solo colocas los endstop en l parte superior no es necesario imprimir la pieza para los endstop (endstop).
Bases
Dos bases en contrachapado, mdf, metacrilato o el material que queramos
Aqui teneis la plantilla para las bases gracias a Goyo Estevez:
Estos son los comentarios de Goyo sobre las bases:
"Es un solo plano que sirve para la base y la tapa. Lo que recomiendo es hacer base y tapa iguales. Los taladros para tornillos M4 son para las piezas impresas, y los de tornillos M3 para base caliente MK2. Haciendo la tapa igual que la base tenemos posibilidad de colocar rigidizadores adicionales (hay gente que pone arriba otro juego de 3 piezas similares a los soportes de los motores para rigidizar el conjunto). Los taladros M3 en la tapa también nos sirven para organizar los cables de los endstops con bridas, p.e."
Correas y Poleas
[En construcción] 5 metros de correa abierta son suficiente. La correa tipo GT2 da el mejor resultado aunque con correa T2.5 funciona igualmente. 3 poleas GT2 de 40 dientes o T2.5 de 32 dientes.
Instrucciones
Todavía No hay instrucciones oficiales, pero entre todos lo iremos sacando
Enlaces
Proyecto Clone Wars
