Columbus/repository
Revision as of 13:51, 25 November 2011 by Glenn (talk | contribs) (+ Category:Columbus)
Projects
COL-105
  • This project seeks to design the first physical Columbus device. While the -105 will most likely meet very few of the Gada Prize requirements, it's main objective is to prove that the structure, positioning mechanisms, and software/hardware can all work in concert.
FILE ID# TYPE DESCRIPTION FORMATS UPLOAD INFO
COL-105-0 ASSEMBLY This assembly was created to test the idea of external pocketing of structural panels. .pdf, .stl --Isaac Olson 04:14, 19 August 2010 (UTC)
COL-105-101-0 PART This assembly was created to test the idea of external pocketing of structural panels. .pdf, .stl --Isaac Olson 04:14, 19 August 2010 (UTC)
Nomenclature
Due to the nature and scale of this project it is expected that hundreds – if not thousands – of files will be created to properly document and exploit the various conceptual designs, prototypes, and official releases. Because one can only name a file just so many things before language is exhausted, the following nomenclature will be used for naming all Columbus files:
  • COL-XXX-XXX-XXX-X
  1. All files begin with the first three letters of the Team name, in this case COL.
  2. The second set of three digits represent the project the component is in.
    • If a file is purely experimental then it may be noted as such by substituting the project name with "TEST". Example: COL-TEST-150-...
  3. The third set of three digits represent the assembly within the project.
  4. The fourth set of three digits represents the part number within the assembly.
  5. The last placeholder represents the release status: an uppercase letter for released revisions (A,B,C...) or a number for unreleased revisions (1,2,3...)
    • For released revisions the letters I (as in iceberg) and O (as in orange) are skipped due to their similar appearance to 1 and 0 respectively.
  6. Example: COL-125-010-007-B. This is read as: Columbus, project 125, assembly 10, part 7, revision B.
Files Types
  • ASSEMBLY
This is a CAD solid model assembly, it contains multiple parts. Assembly files will always be located at the top of the file table.
  • PART
This file contains a single CAD solid model.
Formats
Any file format that includes the word 'all' contains a complete set of the particular file for each component in the assembly.
  • 2D Files
.pdf
all.pdf
.dxf
  • 3D Files
.stl
.step
.sldasm
.sldprt
  • Code Files
