ConductiveMaterials
Revision as of 20:37, 24 April 2011 by Chip936 (talk | contribs)
This page lists the results of conductive paints, sealants, glues and epoxies which could be extruded.
Graphite added to Bitumen
Bitumen is a brushable waterproofer sealant used on roofs. It hardens into a flexible rubber.
Materials
  • Bitumen Brushable Waterproofer - 500ml AU$ 8.64
  • Graphite - Lock-Lube - 6g AU$ 6.11
Results
  • 10ml of bitumen and 1g of graphite. Result - >2M Ohms
  • 10ml of bitumen and 2g of graphite. Result - 34k Ohms/cm
  • 10ml of bitumen and 3g of graphite. Result - 500-1k/cm Ohms
Notes
Additional graphite was added to the existing solution after the sample trace was drawn. At 3g of graphite the mixture was thick and difficult to mix and manipulate with a the toothpick I used to lay down the test trace. Paint thinner should be added to the mixture and tested.
External Links
More on making conductive glue circuits. An instuctable on how to make conductive glue circuits.
