Crimping/ru
Revision as of 16:30, 28 December 2017 by Edlab (talk | contribs) (Created page with "{{Languages}} thumb|380px|right|Lug and ferrules terminals One of the most frequent method to connect terminals/ferrules to wires is...")
One of the most frequent method to connect terminals/ferrules to wires is to crimp them. Insulated (automotive type), uninsulated and ferrules need different crimping tool, which are also different from the dupont crimping tool. For the mains, it is also possible to use rigid wires, which don't need ferrules. It is not normal practice for machinery, but could be ok for a machine with negligible vibrations. You may decide according local regulations for machinery.
Using crimped ferrules /sleeves
It is preferable to use crimped ferrules on stranded wires and in a lot of countries, it is compulsory for machinery.
Bootlace ferrules for stranded wires
Ferrules
Ferrule crimped with Knipex plier
Good quality Ferrule crimping plier Knipex 97 72 180, 29 Euros.
For ferrules, you could also use the more common square crimper, search words 'HSC8 crimping'.
Using insulated terminals
Insulated terminals, crimped with PL55
Insulated terminals 'faston' type, eyed or round terminals are crimped in two zones, one for electrical connection and the other for good locking of wire insulation. For this kind of insulated terminals, the colour is associated with wire size. It is also possible to use uninsulated terminals with thermo-retractable sleeve, but this need other kind of crimping tool. These type of terminals may not work well on small wires, so it is preferable with low cost crimp tools to use at minimum 1.5mm2 wires.
Top: Silverline PL55, 14 euros - Bottom: standard tool as found in low cost sets
note the colour mark on tool, same as terminal colour
The Silverline ratchet tool PL55 is not the best quality but is more usable than the basic tool sold with terminals assortments which needs athletic capabilities. The ratchet tool may need adjustment (see the teethed wheel on the side).
Dupont terminals
Dupont terminals are low cost and as the power carried in a printer is low, they could be used for anything except heating. The problem is they are quite difficult to crimp with ordinary pliers. So you need a ratchet type crimp tool and learn to use it. It is NOT recommended to solder, as this create a hard point which under stress, WILL break one day. Molex connectors are better, but more costly. Note that to remove a dupont pin or plug, you need to lift the small plastic tongue locking it with a micro screwdriver.
Ratchet tool SN28B, 13 euros
Wire stripper
There are miscellaneous kind of wire strippers. They guaranty good work with no cutted strand. The model shown on photo is not the most common but fairly practical as it automatically adjust to the wire size.
Face automatic wire stripper Jokari 20050, 22 Euros
See also
External links
Video of bootlace ferrule crimping
In addition to site licence GFDL1.2, this page is also released under license CC BY-SA 4.0
