Cyclone PCB Factory/build
In this section i will be quick showing more or less how the mechanics should be assemble
Here you can see more or less all the basics parts that you need. You can see all printed parts. also nuts, screws, rods, stepper motors, drivers, etc
First cut and drill the base. i did sent them to laser cut and laser drill to avid miss aligments. Then paint them with the color that you want. i did use MDF wood. Glue with silicon Rubbers to avoid nuts scratch the table surface.
put the bolts and nuts to the 2 laterals and tight them not to much we need them lose so later we can align all the machine.
