Darlington power transistor
Revision as of 09:46, 30 December 2014 by Glenn (talk | contribs) (Glenn moved page DarlingtonPowerTransistor to Darlington power transistor)
Darlington Power Transistor (NPN)
This little guy is great for powering devices with an IC. it's basically two transistors in the same package; one connects to the low-powered output from the PIC, and drives the other one enthusiastically. The net effect is that you can use the tiny current available from a PIC output pin to efficiently switch currents of several amps.
More info in Wikipedia...
