DarwinDesignFaults
Darwin Design Fault Log
Hi, if there's any design faults you've discovered on the way to building your Darwin, please log them here...
Victim | *Problem* | ||
Adrian | Can't reach lower belt clamp bolts on the X carriage, unless with a rounded hex key | ||
Adrian | X Belt clamp label wrong above "X axis assembly" in figure | ||
Adrian | Notch the hypotenuse of the bed corner plates so it jigs up better | ||
Adrian | 20mm caps on tensioner corners? (More travel) | ||
Chris | Moulds for X & Y pulleys too small, I suggest 14mm for 16 teeth | ||
Chris | Idler pulleys too big, should match drive pulleys | ||
Chris | X-motor bracket is too low to meet the Y belt | ||
Chris | Y & Y flags should enter opto from the side | ||
Chris | Z flag should have a flat top | ||
Chris | Y belt clamp has a pitch of 13mm but the holes in the x-carriage are 12mm | ||
Chris | The slot in the opto-brackets is slighly too small for the five pin opto |
Thanks!
-- Main.EdSells - 20 Apr 2007
