DarwinExtruderBOM
Darwin Extruder Bill of Materials
Part | No. off | material | Supplier | In picture |
clamp | 1 | polycaprolactone | RP part | A |
motor holder | 1 | polycaprolactone | RP part | B |
hex drive | 1 | polycaprolactone | RP part | C |
polymer holder | 1 | polycaprolactone | RP part | O |
screw holder | 1 | polycaprolactone | RP part | P |
PTFE barrel holder | 1 | 16mm PTFE rod | D | |
Extruder controller | 1 | - | instructions | E |
200:1 geared motor | 1 | - | Greenweld (CDT0302) Pololu (GM3) | K |
Heater barrel | M6 brass/steel/Al studding | J | ||
200mm Heater wire | 1 | 0.2mm nichrome | Pelicanwire (32 AWG NICHROME 80) | J |
M6 dome nut | 1 | brass/steel/Al | Hardware shop | I |
thermistor | 1 | glass bead type | RS (484-0149) | I |
Half bearing | 2 | brass | - | P |
Screw drive | 1 | M5 steel studding | - | Q |
Flexible coupling | 1 | 3mm steel wire | - | Q |
M5 Drive nut | 1 | brass/steel | - | Q |
PCB screw | 1 | M3 15mm cap screw | - | F |
25 mm screws | 4 | M3 cap screws | - | F |
35 mm screws | 7 | M3 cap screws | - | F |
guide screws | 4 | 55mm M3 studding | - | L |
clamp screw | 1 | 30 mm M4 cap screw | - | R |
M4 washers | 2 | brass/steel | - | S |
M4 nut | 2 | brass/steel | - | T |
M3 nuts | 20 | brass/steel | - | H |
M3 washers | 34 | brass/steel | - | G |
Silicone tube | 100 mm | 3mm internal | - | M, N |
Grease | 1 small tub | - | Hardware shop | P |
high-temp epoxy | 1 set | JB Weld | Hardware shop | I, J |
The picture has 32 M3 washers, but you need 34 (no one's perfect...). Where the material says brass/steel you can choose either, but see the ExtruderMechanicalParts page for more details. There is no significance to the fact that the clamp is green in the picture - we were just trying out a different coloured polymer.
-- Main.AdrianBowyer - 06 May 2007
