Darwin corner bracket
Revision as of 05:44, 19 August 2013 by Traumflug (talk | contribs) (Undo revision 102589 by Domtheos (Talk))
This is the corner bracket for the Darwin design. It's the gnarliest bit in the assembly, so it's up here for test purposes.
Assembly Instructions
Insert nuts where suitable before inserting ø8mm or 5/16" bar to clamp with bolt.
Files
File format Extension File (click to download) Approx File Size How created Comments
STL .stl File:Corner bracket.stl or [1] 15Mb Exported from SolidEdge v19 Darwin test piece
