Drive-gear
Revision as of 06:19, 3 May 2013 by Snipermand (talk | contribs)
Drive-gears to be used in direct drive and some other extruders (like the Adrian's_Geared_Extruder).
Model From Length Outer diam. Hob diam. Bore Approximate Cost Additional notes
RepRap.me
MK7 Drive Gear
EU/Denmark 11 mm 12,5 mm 10,65 mm 5 mm 11 $ Makerbot drive-gear.jpg
The best drive gear on the market. Made in stainless steel and are good for both 1.75 and 3.00mm filament.
Mendel-Parts hobbed shaft
stainless-steel insert
brass insert
Netherlands  ? mm  ? mm  ? mm M4, M5, M6
5,1 mm
14 €
4€
3€
Mendel-parts drive-gear v2.jpg stainless steel
QU-BD US 11.03 mm 11.64 mm 10.5 mm 5 mm 7,50 $ Qubd drive-gear.jpg Brass alloy. (maybe better suited for 3mm than 1,75mm)
RepRapWorld Netherlands 10 mm 12 mm  ? mm 5 mm 8 € Reprapworld drive-gear.jpg "mk7 compatible"
Mini-hyena Hungary 13 mm 8 mm
11 mm
11 mm
13 mm
6 mm
9 mm
9 mm
11 mm
5 mm
5 mm
8 mm
8 mm
12 $ Mini-hyena 5x8.jpg Mini-hyena 5x11.jpg made by Arcol !
TrinityLabs hobbed pulley US 11 mm 13 mm 11 mm 5 - 8 mm 8$ by BLDDK (you may ask him or ezmobius on the IRC
Brass insert
Conrad.com
Conrad-uk
EU
UK
 ? mm  ? mm  ? mm M4 3 €
4 £
Maritime-models UK  ? mm  ? mm  ? mm many 1,80 £ Maritime-models drive-gear.jpg need some use to grip more effectively Maritime-models drive-gear close-up.jpg
