EMAKER Huxley
EMAKER Huxley
Release status: experimental
Description | |
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
This is a redesigned Huxley inspired by the Prusa simplified Mendel. The information on this wiki page is not yet complete, so do not attempt to build this machine. I will keep updating this page over the next few days until there is enough information on here for a complete build of the eMAKER Huxley design.
Files
FILE ID# | TYPE | DESCRIPTION | AVAILABLE FORMATS | CREATED/RESERVED BY |
Your-File-Name | SOLID MODEL ASSEMBLY | These are CAD files for the Solid Model Assembly | N/A | --Example User 12:00, Today's Date 20xx (UTC) |
EMAKER huxley 00 | STL FILES FOR PARTS | These are STL files for each part. | .stl.zip | --jmgiacalone 12:00, Today's Date 20xx (UTC) |
Your-File-Name | SOLID MODEL ASSEMBLY | This is the final finished machine | N/A | --Example User 12:00, Tomorrow's Date, 20xx (UTC) |
History
Bill of Materials
Printed Parts
Quantity | Description | Type | Comments | Diagram |
2 | coupling-beam | RP | ||
1 | x-idler-bracket | RP | ||
1 | x-motor-bracket | RP | File:Ehux-x-motor-bracket.png50px |
FOR THE EXTRUDER DRIVE see files on thingiverse
1x M4-extruder-block RP 1x beefed-up-idler-pulley RP 1x 9tooth-gear RP 1x 53tooth-gear RP
Non-Printed Parts ("vitamins")
2x Nema 14 bipolar stepper motor, 14Ncm 2x Nema 14 bipolar stepper motor, 6Ncm 50x Small cable binder/ziptie Misc. 1x Electronics + endstops. This can be RAMPS,Generation_7_Electronics, or anything else compatible.
(The eMAKER Huxley uses the 4 drivers in the standard Mendel electronics package to drive 5 motors by using "two steppers wired in parallel to one driver"[1]).
Printing the Parts
Buy the printed parts
Coming soon to eMAKERshop
