EMAKER Huxley
Revision as of 13:39, 12 July 2011 by Jmgiacalone (talk | contribs) (Printed Parts)
EMAKER Huxley
Release status: experimental
unknown
This is a redesigned Huxley inspired by the Prusa simplified Mendel. The information on this wiki page is not yet complete, so do not attempt to build this machine. I will keep updating this page over the next few days until there is enough information on here for a complete build of the eMAKER Huxley design.
Brief specification
  • 140x140x110mm build vollume
  • Heated build surface
  • Bowden fed extruder for 1.75mm filament
History
Bill of Materials
Printed Parts
Quantity Description Type Comments Diagram
2 belt-nut-trap RP
Non-Printed Parts ("vitamins")
2x Nema 14 bipolar stepper motor, 14Ncm
2x Nema 14 bipolar stepper motor, 6Ncm
50x Small cable binder/ziptie       Misc.
6x 6mm Linear bearings
4x 6mm Igus clip bearings
1x 140x140x5mm milled Aluminium build surface
2x T2.5 16 tooth Aluminium timing pulleys
2x T2.5 timing belts
2x 623 bearings
2x 626 bearings
1x Electronics + endstops. This can be RAMPS,Sanguinololu, Generation_7_Electronics, or anything else compatible.
(The eMAKER Huxley uses the 4 drivers in the standard Mendel electronics package to drive 5 motors by using "two steppers wired in parallel to one driver"[1]).
Printing the Parts
The assembled eMAKER Huxley prototype
Buy the printed parts
Coming soon to eMAKERshop
Test Videos
XY axes test
First print
Printing a frame vertex
