EMCRepRap
If you have a CNC machine which you control using EMC2 on GNU/Linux, you can just mount the plastic extruder and start printing using EMC2. See here a video that shows EMC2 printing.
There are at least 2 users that already made an EMCRepStrap and documented and shared their code - brendanjerwin made his EMCRepStrap at 2008 and sam0737 at 2009.
Config EMC for working with plastic extruder
NOTE: This guide follows the work of sam0737 user.
- Download the necessary files from sam0737 account on github.
- In the repstrap-extruder.hal, changes the absolute path to the repstrap-extruder.py script
- In the EMC ini, under the [DISPLAY] section, add the PYVCP, like this:
[DISPLAY]
DISPLAY = axis
PYVCP = /absolute/path/to/repstrap-extruder.pyvcp
- In your EMC ini, there should be a POSTGUI_HALFILE in the [HAL] section. If not, create one :
[HAL]
HALUI = halui
POSTGUI_HALFILE = custom_postgui.hal
- In the customZpostgui.hal, include the repstrap-excluder.hal file, like this :
source /absolute/path/to/repstrap-extruder.hal
- Make a change in the input parameter of "steps_per_mm_cube" in that hal file.
The value is number of encoder steps representing 1mm cube
- Modify RepRapSerialComm.py, make sure the path to your serial device is correct.
- Soft link the mcode-inject.py to M101, M102, M103, say in the shell, you do:
ln -s mcode-inject.py M101
ln -s mcode-inject.py M102
ln -s mcode-inject.py M108
- Make sure all of them are marked as executable, say in the shell, you do:
chmod a+x *.py*
- Hook up your cable and such.
Cheap CNC machines
It's important to find cheap CNC machines, Ebay is a good source for cheap CNC machines.
3 axis CNC - $225
There is one CNC on Ebay for $250. Here is the page from the seller with some pictures and information about his CNC($225).
