Easy Reliable Coupler
Release status: unknown
Description | An easy reliable coupler you can make out of plastic.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Files
- File:Plastic coupler.stl
- File:Plastic coupler.IGS
- (or File:Plastic coupler.some cad file extension.zip if the former link doesn't work.)
FILE ID# | TYPE | DESCRIPTION | AVAILABLE FORMATS | CREATED/RESERVED BY |
Your-File-Name | SOLID MODEL ASSEMBLY | These are CAD files for the Solid Model Assembly | .xml.zip, .stl.zip | --Example User 12:00, Today's Date 20xx (UTC) |
Your-File-Name | CAD FILES FOR PARTS | These are CAD files for each part. | .xml.zip, .stl.zip | --Example User 12:00, Today's Date 20xx (UTC) |
Your-File-Name | SOLID MODEL ASSEMBLY | This is the final finished machine | N/A | --Example User 12:00, Tomorrow's Date, 20xx (UTC) |
I have finally come up with a solution for an easy reliable coupler you can make out of plastic. The attached STL file is a 3/32 to 1/4 coupler. It is 1/2" long, and 3/4" diameter. It uses 6 #4 nuts that are forced fit into the slots around the hole. This is so that the set screw does not strip out the plastic. 6 #4 X 3/8" set screws go through these nuts and hold the shaft in place. They can be adjusted so that both shafts are perfectly concentric. I have tugged on the shafts, and the set screws hold them very tight. I could not pull them out of the coupler. This should work for all of the motors on the printer. I think it can be reprapped, so try it out. It can be adapted easily for other bore sizes, so if you want a different size, just tell me.
