EinsyRambo development
Revision as of 18:32, 8 January 2018 by Tonokip (talk | contribs) (initial pin map)
RAMBo Pages: RAMBo .:. RAMBo v1.0-1.1 .:. RAMBo v1.2 .:. RAMBo Firmware .:. RAMBo Development .:. MiniRambo .:. MiniRambo Development .:. EinsyRambo .:. EinsyRambo Development
This page contains information relevant to the development of the EinsyRambo PCB. You can find general info at EinsyRambo.
Pins
The extension headers are in the format "Extension Name" "Pin Number" "Function". Example: MX1-5 Direction = "Motor Extension 1" "Pin 5".
Pin Number Pin Number Arduino Pin Name Function
1 PG5 ( OC0B ) Digital pin 4 (PWM) Bed Heater
2 PE0 ( RXD0/PCINT8 ) Digital pin 0 (PWM) (RX0) USB – serial comms
3 PE1 ( TXD0 ) Digital pin 1 (PWM) (TX0) USB – serial comms
4 PE2 ( XCK0/AIN0 ) RamboDigital pin 78
5 PE3 ( OC3A/AIN1 ) Digital pin 5 (PWM) P2 1
6 PE4 ( OC3B/INT4 ) Digital pin 2 (PWM) nAC_FAULT, J19 3
7 PE5 ( OC3C/INT5 ) Digital pin 3 (PWM) Heat 0
8 PE6 ( T3/INT6 ) RamboDigital pin 79
9 PE7 ( CLKO/ICP3/INT7 ) RamboDigital pin 80
10 VCC VCC VCC
11 GND GND GND
12 PH0 ( RXD2 ) Digital pin 17 (RX2) P3 5
13 PH1 ( TXD2 ) Digital pin 16 (TX2) P3 3
14 PH2 ( XCK2 ) RamboDigital pin 84 P1 10 (LCD Beeper)
15 PH3 ( OC4A ) Digital pin 6 (PWM) Fan 2
16 PH4 ( OC4B ) Digital pin 7 (PWM)
17 PH5 ( OC4C ) Digital pin 8 (PWM) Fan 1
18 PH6 ( OC2B ) Digital pin 9 (PWM) P1 9 (LCD BTN Click)
19 PB0 ( SS/PCINT0 ) Digital pin 53 (PWM)(SPI-SS) J19 5
20 PB1 ( SCK/PCINT1 ) Digital pin 52 (PWM)(SCK) P2 9, J19 11
21 PB2 ( MOSI/PCINT2 ) Digital pin 51 (PWM)(MOSI) P2 5, J19 12
22 PB3 ( MISO/PCINT3 ) Digital pin 50(MISO) P2 10, J19 9
23 PB4 ( OC2A/PCINT4 ) Digital pin 10 (PWM) Z Min Endstop
24 PB5 ( OC1A/PCINT5 ) Digital pin 11 (PWM) Y Min Endstop
25 PB6 ( OC1B/PCINT6 ) Digital pin 12 (PWM) X Min Endstop
26 PB7 ( OC0A/OC1C/PCINT7 ) Digital pin 13 (PWM) LED
27 PH7 ( T4 ) RamboDigital pin 85 P1 4 (LCD D6)
28 PG3 ( TOSC2 ) RamboDigital pin 71 P1 3 (LCD D7)
29 PG4 ( TOSC1 ) RamboDigital pin 70 P1 5 (LCD D5)
30 RESET RESET Reset
31 VCC VCC VCC
32 GND GND GND
33 XTAL2 XTAL2 XTAL2
34 XTAL1 XTAL1 XTAL1
35 PL0 ( ICP4 ) Digital pin 49 X Direction
36 PL1 ( ICP5 ) Digital pin 48 Y Direction
37 PL2 ( T5 ) Digital pin 47 Z Direction
38 PL3 ( OC5A ) Digital pin 46 (PWM)
39 PL4 ( OC5B ) Digital pin 45 (PWM)
40 PL5 ( OC5C ) Digital pin 44 (PWM)
41 PL6 Digital pin 43 E Direction
42 PL7 Digital pin 42
43 PD0 ( SCL/INT0 ) Digital pin 21 (SCL) P3 6
44 PD1 ( SDA/INT1 ) Digital pin 20 (SDA) P3 8
45 PD2 ( RXDI/INT2 ) Digital pin 19 (RX1) J19 6
46 PD3 ( TXD1/INT3 ) Digital pin 18 (TX1) J19 8
47 PD4 ( ICP1 ) RamboDigital pin 81
48 PD5 ( XCK1 ) RamboDigital pin 82 P1 7 (LCD RS)
49 PD6 ( T1 ) RamboDigital pin 83
50 PD7 ( T0 ) Digital pin 38
51 PG0 ( WR ) Digital pin 41 X Chipselect
52 PG1 ( RD ) Digital pin 40
53 PC0 ( A8 ) Digital pin 37 X Step
54 PC1 ( A9 ) Digital pin 36 Y Step
55 PC2 ( A10 ) Digital pin 35 Z Step
56 PC3 ( A11 ) Digital pin 34 E0 Step
57 PC4 ( A12 ) Digital pin 33
58 PC5 ( A13 ) Digital pin 32 SPI Flash Chipselect
59 PC6 ( A14 ) Digital pin 31
60 PC7 ( A15 ) Digital pin 30
61 VCC VCC VCC
62 GND GND GND
63 PJ0 ( RXD3/PCINT9 ) Digital pin 15 (RX3) P2 4 (LCD SD Detect)
64 PJ1 ( TXD3/PCINT10 ) Digital pin 14 (TX3) P2 6 (LCD BTN_EN1)
65 PJ2 ( XCK3/PCINT11 ) RamboDigital pin 72 P2 8 (LCD BTN_EN2)
66 PJ3 ( PCINT12 ) RamboDigital pin 73 J19 7
67 PJ4 ( PCINT13 ) RamboDigital pin 75
68 PJ5 ( PCINT14 ) RamboDigital pin 76 P3 9
69 PJ6 ( PCINT 15 ) RamboDigital pin 77 P2 7 (SDSS)
70 PG2 ( ALE ) Digital pin 39 Y Chipselect
71 PA7 ( AD7 ) Digital pin 29 X Enable
72 PA6 ( AD6 ) Digital pin 28 Y Enable
73 PA5 ( AD5 ) Digital pin 27 Z Enable
74 PA4 ( AD4 ) Digital pin 26 E0 Enable
75 PA3 ( AD3 ) Digital pin 25
76 PA2 ( AD2 ) Digital pin 24 Z Probe Thermistor
77 PA1 ( AD1 ) Digital pin 23
78 PA0 ( AD0 ) Digital pin 22
79 PJ7 RamboDigital pin 74
80 VCC VCC VCC
81 GND GND GND
82 PK7 ( ADC15/PCINT23 ) Analog pin 15 (69) Y Diag
83 PK6 ( ADC14/PCINT22 ) Analog pin 14 (68) Z Diag
84 PK5 ( ADC13/PCINT21 ) Analog pin 13 (67) Z Chipselect
85 PK4 ( ADC12/PCINT20 ) Analog pin 12 (66) E Chipselect
86 PK3 ( ADC11/PCINT19 ) Analog pin 11 (65) E Diag
87 PK2 ( ADC10/PCINT18 ) Analog pin 10 (64) X Diag
88 PK1 ( ADC9/PCINT17 ) Analog pin 9 (63)
89 PK0 ( ADC8/PCINT16 ) Analog pin 8 (62) P3 10
90 PF7 ( ADC7/PCINT15 ) Analog pin 7 (61) P1 8 (LCD Enable)
91 PF6 ( ADC6/PCINT14 ) Analog pin 6 (60)
92 PF5 ( ADC5/TMS ) Analog pin 5 (59) P1 6 (LCD D4)
93 PF4 ( ADC4/TMK ) Analog pin 4 (58)
94 PF3 ( ADC3 ) Analog pin 3 (57)
95 PF2 ( ADC2 ) Analog pin 2 (56) Thermistor 2
96 PF1 ( ADC1 ) Analog pin 1 (55) Thermistor 1
97 PF0 ( ADC0 ) Analog pin 0 (54) Thermistor 0
98 AREF Analog Reference
99 GND GND GND
100 AVCC VCC VCC
