Electronics Variations
Description | |
License | |
Author | unknown
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
Gen X naming convention/s.
This "Gen X" naming convention for electronics after Gen3 is getting stupid, and is wrong. This page is an attempt at dis-ambiguation of the terminology, and correction of a number of mistakes. For a better description of all the alternative elctronics themselves, please see [[1]].
It started of sensibly:
[Gen1] was PIC based. (our first CPU type) [(generation 1 electronics)] The PIC electronics have been superseded since before the "Darwin" model. The PIC electronics are no longer recommended.
[Gen2] was Arduino Based. ( essentially) ( our second CPU type and architectural change) [(generation 2 electronics)]
[Gen3] was a dual CPU system, Sanguino+Arduino Based. ( our third CPU type and architectural change) the most common form of this is "Makerbot Gen 3 electronics".
Following this it just went stupid:
[Gen4] was never made (although designed were released by Makerbot), just talked about, and was going to be based on Arduino Mega. ( our fourth CPU type and architectural change)
Gen5 was never made, and just an idea, based on a Small Form-factor Linux computer, and was never made, and should never have had a title like this.
[Gen6] is the name for a single commercial variant of "single board" Sanguino electronics, which should rightly be called "mendel-parts.com integrated Gen 3 electronics"
[Gen7] is the name for a single variant of supposedly easy-to-make "single board" Sanguino electronics, which should be rightly called "Traumflug integrated Pololu electronics".
[Gen8] may still be in flux, and should be rightly called "Chris Parkinson xxxxxx electronics".
Then there are those that ( smartly) don't use the "Gen X" naming convention:
Techzone Remix ( electrically equivalent to Makerbot Gen3, therefor it's a Gen 3)
Pololu Electronics - ( based on a Mega CPU, so based on the theoretical Gen4=Mega description, it's a Gen4 design). http://www.reprap.org/wiki/Pololu_Electronics
Arduino Mega Pololu Shield - based on Adrian's Gen4, and used an Ardiono Mega, so it's a Gen4 too. http://www.reprap.org/wiki/Arduino_Mega_Pololu_Shield
then there's a bunch of alternative pololu based designs that nearly all use the Mega CPU as a basis, and they should all be called "Gen 4".
Finally, there is the ARM STM32 ideas, which if we had a time machine could/should have been called Gen5 electronics ( but only if they get built, and documented, and duplicated), since the Gen5 title was actually never used, but now it'll probably end up being called "Gen 300" or something equally meaningless.
Let's say I want to describe "all Sanguino-based electronics", it used to be that I said "Gen 3", now I have no idea.?
Possible Fix
I kind of like poetic or whimsical names as opposed to numbers for electronics. RAMPS or Arduino is interesting and fun. Numbers are not, and some devs will not want to use them. I'm thinking we could start using "chipname+{random color}+{foodstuff}" for the drive-by uploads / stuff that we help seed in the wiki. It would be a good way to distinguish between boards and would effectively sidestep the rather unfair feeling that 'gen n+1>gen n'. For example, "STM32 blue banana electronics" or "PIC32F purple sushi electronics". It is better than "Ampere" or "Volt", and it is better than generation N+1. The slight silliness makes each board fun, memorable, and distinctive, which is extremely helpful. Also, it's fairly clear that the {random color} and {food stuff} is not a chip name, unlike: "STM32-{number} electronics" or "PIC32F-{letter} electronics" Perhaps I'll use "chipname+{random color}+{foodstuff}" to seed pages until someone proposes something better. It's a workable system, and feels better than the Generation N+1 system. And frankly, I'm just happy when we have the full url on the board, and the files in the wiki. --Sebastien Bailard 04:31, 1 November 2010 (UTC)
