Extruded Aluminum
Revision as of 11:19, 5 February 2018 by DGoncz (talk | contribs)
This page has been flagged as containing duplicate material that T-Slot also attempts to cover.
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
Please do not add to this page. (It is slightly overcrowded as it is.)
This Page Contains multiple RepRap development projects and should be split up. Each individual project/design/improvement should have its own development page within an encompassing category.
Aluminum is one of the more popular frame materials.
kinds of extruded aluminum
T-Slot is one of the most popular categories of extruded aluminum -- VSlot, fischertechnik aluminum beams, 80/20 beams, MakerBeam, OpenBeam, MicroRAX -- see T-Slot for more details.
aluminum L rails: Doboz
MakerSlide is an open source aluminum extrusion with a built-in V-rail linear bearing system. The Deltic3D, ORD bot, Freedeepee, CNC Router, etc. all use MakerSlide as part of their drive train.
YesRail, apparently designed for the P2f RepStrap, is a rail system "based on Open Rail and MakerSlide".
OpenRail: Linear V rail universal mounts to t-slot extrusion
aluminum L rails
RobotDigg
EZ Tube
Telescoping
Makeblock: typically used for small desktop models
Early version of Eiffel, showing the grid beam TriLap joints. (The beams should have through-holes repeating along the side.)
grid beam: square beams with a line of holes: typically used for furniture and street signs
Makeralot
Extruded rectangular aluminum tubes:
square metal tubes, that later have holes drilled only where bolts are needed, as in T-Rep 0 (the progenitor) and Strapzilla and TeeBot <flickr>3951997454|none</flickr> <flickr>5084805984|right</flickr>
