Extruder/Mendel
Mendel uses a thermoplast extruder based on RepRap's Thermoplast Extruder Version 2.0. The principle is exactly the same, but a redesign has condensed the RP parts into one component (click here for instructions on how to get hold of RepRapped parts). The non-RP parts remain the same, therefore please refer to the Thermoplast Extruder Version 2.0 documentation to assemble the non-RP components. The rest of this page will deal with the new assembly only.
BOM
Assembly qty: 1
Name | Qty/assembly | Total Qty | Type |
Thermal-barrier and nozzle | 1 | 1 | Assembly |
pinch-wheel-bracket-NEMA17_604-bearing_1off.par | 1 | 1 | RP |
m3-capx20.par | 4 | 4 | Fastener |
m3-washer.par | 4 | 4 | Fastener |
624-bearing.par | 1 | 1 | Bearing |
m4-nylock.par | 1 | 1 | Fastener |
m4-washer.par | 5 | 5 | Fastener |
m4x16-cap.par | 1 | 1 | Fastener |
m4x40-cap.par | 2 | 2 | Fastener |
stepper-motor-nema17-fl42sth47-1684A-01.par | 1 | 1 | Motor |
RP parts
Assembly
- Secure bearing using M4x16 cap, and glue nozzle assembly into pinch wheel bracket. Follow Thermoplast Extruder Version 2.0 documentation for gluing procedure. Note orientation of copper barrel tang.
- Loosely attach motor. Motor wires should run upwards. Set distance between motor shaft and bearing to 2.5 mm – use the round shank of a 2.5 mm drill bit poked down the filament hole as a spacer. Lock motor into position. Load M4x40 caps for ready for next step.
Back to Mendel mechanical construction root.
