ExtruderController
Revision as of 05:36, 11 January 2015 by Glenn (talk | contribs) (catchg)
Extruder Controller SNAP Protocol Version 0
API
[0] Get Version
Returns the version of the module. This message is the only message universally supported by all devices and is therefore useful as a test.
Parameters:
  • None
Returns:
  • 1 byte: Response type (0)
  • 1 byte: minor version number
  • 1 byte: major version number
[1] Set forward motion
Starts the motor turning indefinitely in a forward direction. If the motor reaches the maximum position sensor (as defined by the maximum optointerrupter input), motion will stop.
Parameters:
  • 1 byte: Speed to turn (0 to 255)
Returns:
  • Nothing
[2] Set reverse motion
Starts the motor turning indefinitely in a reverse direction. If the motor reaches the minimum position sensor (as defined by the minimum optointerrupter input), motion will stop.
Parameters:
Returns:
  • Nothing
[3] Set position counter
Parameters:
  • 1 byte: low order byte of 16 bit position counter
  • 1 byte: high order byte of 16 bit position counter
Returns:
  • Nothing
[4] Get position counter
Parameters:
  • Nothing
Returns:
[5] Seek to position
Parameters:
  • 1 byte: Speed to move (1 to 255)
  • 1 byte: low order byte of 16 bit target position
  • 1 byte: high order byte of 16 bit target position
[6] Power down motor (torque off)
This is provided for compatibility with the Stepper Motor Controller API Version 0. In the case of the Extruder, this just stops extrusion. It is equivalent to setting the speed to 0.
Parameters:
  • None
Returns:
  • Nothing
[7] Enable asynchronous notifications
This is provided for compatibility with the Stepper Motor Controller API Version 0. In the case of the Extruder, this doesnt do anything.
Parameters:
  • 1 byte: address to notify
Returns:
  • Nothing
[8] Check if material is empty
Parameters:
  • Nothing
Returns:
  • 1 byte: 1 if empty, 0 if not empty
[9] Set heater output
Parameters:
  • 1 byte: PWM for heater on low setting (target < heat < max)
  • 1 byte: PWM for heater on low setting (heat < target)
  • 1 byte: target temperature for extruder (formatted for PIC timer)
  • 1 byte: maximum temperature for extruder (formatted for PIC timer)
Returns:
  • Nothing
[10] Get current heater temperature
Parameters:
  • Nothing
Returns:
  • 1 byte: temperature as measured in PIC timer format.
[52] Set voltage reference
Used to re-range the A/D temperature measurements to give the best possible precision. The general principle of ranging is to select the value that provides the largest possible temperature reading without overflowing beyond 255.
Firmware
There are two different versions of firmware: older, stable firmware designed for the PIC16F648 and newer firmware designed for the Arduino. They both function identically, and accept the same commands.
PIC Based Firmware
PIC16F628 code images and source are available from SourceForge.
More information on the electronics required to process the commands is located here.
Arduino Based Firmware
The Arduino is a much more powerful microcontroller board based on the atmega168, and it includes more advanced features such as an Analog to Digital Converter, which allows us to measure the temperature much more easily and robustly. Since the protocol is designed around the PIC microprocessor, the Arduino converts its temperature reading to the PIC timer based format.
Arduino firmware is available from SourceForge.
