Extruder development
Revision as of 01:03, 4 January 2011 by AnthongRedbeard (talk | contribs)
collaboration page for ideas on new extruder development, started for the Atlanta area hackerspace freesideatl.
Ongoing discussion
I'd be honored if you guys join the technical-but-friendly dev list, since you guys are devs.  :D
http://reprap.org/pipermail/reprap-dev/
--Sebastien Bailard 04:13, 4 January 2011 (UTC)
Major Models For Comparison
Mendel Stepper Extruder
Wades Geared NEMA 17 Extruder
Guiding Principals
  • Cheap
  • Easy to reproduce
  • Follows in reprap principles
Current issues
Filament Drive
idea bucket
  • Try different material for gripping filament such as sugru / oogoo
  • Make the filament visible until it enters the hot end.
  • Add a rotary encoder to the idler wheel to detect if the filament is advancing. http://www.sparkfun.com/products/9117
  • hinge the idler idler block and add the tension on the outside of the block instead of through it so it can be easily removed.
  • make it easier to replace the hot end.
  • make the mounting to the printer easier, try a gravity mount, or hold in place with paper clamps
Hot End
idea bucket
  • make it easier to remove from filament drive.
  • remove PTFE, don't use any parts that break down at typical extruding temperatures like ABS
  • try make a combo heater block/nozzle
  • try various cheap and off the shelf heatsinks like the copper pipe cap.
  • compare resistance wire to resistor and other options,
    • wind your own resistor to make it as hot as possible?
