Extruder development
Revision as of 01:09, 4 January 2011 by AnthongRedbeard (talk | contribs) (→Wades Geared NEMA 17 Extruder)
collaboration page for ideas on new extruder development, started for the Atlanta area hackerspace freesideatl.
Ongoing discussion
I'd be honored if you guys join the technical-but-friendly dev list, since you guys are devs. :D http://reprap.org/pipermail/reprap-dev/ --Sebastien Bailard 04:13, 4 January 2011 (UTC)
Major Models For Comparison
Mendel Stepper Extruder
- Simple Design, easy to modify
- Simple print.
- Common
- cannot see the filament
- Labor intensive to do any type of maintenance.
Guiding Principals
- Cheap
- Easy to reproduce
- Follows in reprap principles
Current issues
Filament Drive
idea bucket
- Try different material for gripping filament such as sugru / oogoo
- Make the filament visible until it enters the hot end.
- Add a rotary encoder to the idler wheel to detect if the filament is advancing. http://www.sparkfun.com/products/9117
- hinge the idler idler block and add the tension on the outside of the block instead of through it so it can be easily removed.
- make it easier to replace the hot end.
- make the mounting to the printer easier, try a gravity mount, or hold in place with paper clamps
Hot End
idea bucket
- make it easier to remove from filament drive.
- remove PTFE, don't use any parts that break down at typical extruding temperatures like ABS
- trying fiberglass
- try make a combo heater block/nozzle
- try various cheap and off the shelf heatsinks like the copper pipe cap.
- off the shelf nozzles, mechanical pencils, misting nozzles, airbrush nozzles
- compare resistance wire to resistor and other options,
- wind your own resistor to make it as hot as possible?
