Fan
Revision as of 08:16, 7 November 2014 by Traumflug (talk | contribs) (Related links)
We use small or big fans for all sort of things : from cooling the stepper driver, motors, hotend, or the printed plastic itself...
They are easily salvaged from old computer but here is some, with their suppliers and specs to compare. You are welcome to complete the blanks if you know missing information.
Model From Size Speed (RPM) Flow (m^3/h) Volt Amp Watts Noise Approximate Cost Additional notes
Akasa ebay UK 40 x 40 x 11 mm 5000 8,83 12  ?  ? 20,03 dB 6 € used in the RepRapPro Hotend at 19 V, at 12V you almost don't hear it blowing
Geeetech 40mm CN 40 x 40 x 15 mm  ?  ? 12 0.11A  ?  ? 3 € -
Geeetech 30mm CN 30 x 30 x ? mm  ?  ? 12  ?  ?  ? 3.3 € -
Mendel-parts 40mm Sunon Netherland 40 x 40 x ? mm  ?  ? 12 0,16 A  ?  ? 4 € -
Mendel-parts 60mm Netherland 60 x 60 x ? mm 4000 30,2 12 0,16 A  ? 31 dB 3 € -
Sunon KDE1204PFS2-11 Neuhold Elektronik Germany 40 x 40 x 10 mm 5800 11,89 12 0,09 A 1,1 W 28,5 dB 4 € (they also sell a cheap radial fan)
Sunon PMD1204PQBX-A US / Jameco 40 x 40 x 28 mm 13000 40 12 0.57A 6.8W 51.5 dB $12 Loud and powerful server fan
TaoTac.com VN 40 x 40 x 15 mm  ?  ? 12 0.11A  ?  ? 150000 VND -
ReprapUniverse.com 30mm Netherlands 30 x 30 x 10 mm  ?  ? 12 0,09 A  ?  ? € 3,50 High Quality Fan. Cheap International Shipping.
ReprapUniverse.com 40mm Netherlands 40 x 40 x 10 mm  ?  ? 12 0,09 A  ?  ? € 3.25 High Quality Fan. Cheap International Shipping.
RepRapWorld 30mm Netherlands 30 x 30 x 10 mm  ?  ? 12 0,06 A  ?  ? 3 € -
RepRapWorld 40mm Netherlands 40 x 40 x 10 mm  ?  ? 12 0,09 A  ?  ? 3 € -
RepRapWorld 60mm Netherlands 60 x 60 x 25 mm  ?  ? 12 0,23 A  ?  ? 12 € -
Ultimachine 40mm Kysan US 40 x 40 x 10 mm 7000 11,3 12 0,12 A  ? 28 dB 2.50 $ -
eMotionTech 40mm France 40 x 40 x 10 mm  ?  ? 12 0,06 A  ?  ? 2.50 € -
eMotionTech 60mm France 60 x 60 x 10 mm  ?  ?  ?  ?  ? 28 dB 3 € -
QU-BD US 40 x 40 x 10 mm 8700 13,6 12 .15A 1.8W 34 dB 2 $ -
3D Maker World US 40 x 40 x 10 mm 6000 9.77 (5.75 CFM) 12 .08 A  ? 24 dB 2.50 $ Sleeving Bearing
3D Maker World US 40 x 40 x 10 mm 6000 9.77 (5.75 CFM) 12 .06 A  ? 24 dB 5.50 $ Ball Bearing
3D Maker World US 40 x 40 x 10 mm 6000 9.77 (5.75 CFM) 24 .10 A  ? 24 dB 4.50 $ Sleeving Bearing
3D Maker World US 40 x 40 x 10 mm 6000 9.77 (5.75 CFM) 24 .06 A  ? 24 dB 6.50 $ Ball Bearing
3D Maker World US 50 x 50 x 10 mm 5000 15.55 (9.15 CFM) 24 .08 A  ? 27 dB 5.50 $ Sleeving Bearing
DIY-India.com India 40 x 40 x 10 mm 5000 15.55 (9.15 CFM) 24 .08 A  ? 27 dB - Sleeving Bearing
Add model here From Size Speed (RPM) Flow (m^3/h) Volt Amp Watts Noise Approximate Cost Additional notes
Related links
