File:Adaptacion Husillos.zip
Revision as of 15:42, 28 November 2013 by AnavarroCW (talk | contribs) (Adaptación para usar husillos de 10mm de diámetro en la P3Steel)
Adaptacion_Husillos.zip(file size: 685 KB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current20:19, 15 July 2014 (685 KB)AnavarroCW (talk | contribs)Se ha ajustado para dejar más espacio entre el eje X y el marco, ya que tal como estaba antes, quedaba demasiado justo. Se pierde algo (entre 0.5 y 1cm) en el eje Y, pero creo que compensa.
15:42, 28 November 2013 (124 KB)AnavarroCW (talk | contribs)Adaptación para usar husillos de 10mm de diámetro en la P3Steel
  • You cannot overwrite this file.
The following 3 pages link to this file:
