Revision as of 09:12, 11 June 2019 by Henri Starmans (talk | contribs) (Depiction of an array of Hexastorms. The different colors are used to signify depth in the image. In the image, two rows are seen with two columns of laser scanners. Column is the horizontal direction. Naturally, multiple rows and columns might be used...)
Depiction of an array of Hexastorms. The different colors are used to signify depth in the image. In the image, two rows are seen with two columns of laser scanners. Column is the horizontal direction. Naturally, multiple rows and columns might be used to ensure the lines overlap. A camera is also shown which can be used to align the scan heads.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current09:12, 11 June 2019Thumbnail for version as of 09:12, 11 June 2019140 × 236 (10 KB)Henri Starmans (talk | contribs)Depiction of an array of Hexastorms. The different colors are used to signify depth in the image. In the image, two rows are seen with two columns of laser scanners. Column is the horizontal direction. Naturally, multiple rows and columns might be used...
  • You cannot overwrite this file.
The following page links to this file:
