File:Bowden pump closeup fixtures.JPG
Revision as of 11:25, 26 January 2011 by AlexRa (talk | contribs) (Those thingies I've got in a hardware store, and they work nicely to fix the Bowden "pump" to the Huxley frame (the 6mm bars). You should be able to find something similar, or print out a snap-on plastic equivalent.)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current11:25, 26 January 2011Thumbnail for version as of 11:25, 26 January 2011517 × 436 (39 KB)AlexRa (talk | contribs)Those thingies I've got in a hardware store, and they work nicely to fix the Bowden "pump" to the Huxley frame (the 6mm bars). You should be able to find something similar, or print out a snap-on plastic equivalent.
  • You cannot overwrite this file.
The following page links to this file:
Metadata
