File:CPH01 000000000000010009003 00000001 HV transformer Mica.png
Revision as of 06:36, 12 July 2018 by Rapatan (talk | contribs) (This is the mica lasercut template for the mica insulator for the High Voltage Transformer. Dimensions is: 304mm x 200mm x 0,25mm RS stock nr: 785-0815 (6-pack) Need 5 packs of 6 sheats for at total of 151 individual insulators. CPH01_0000000000000...)
Original file(3,169 × 2,274 pixels, file size: 69 KB, MIME type: image/png)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current06:36, 12 July 2018Thumbnail for version as of 06:36, 12 July 20183,169 × 2,274 (69 KB)Rapatan (talk | contribs)This is the mica lasercut template for the mica insulator for the High Voltage Transformer. Dimensions is: 304mm x 200mm x 0,25mm RS stock nr: 785-0815 (6-pack) Need 5 packs of 6 sheats for at total of 151 individual insulators. CPH01_0000000000000...
  • You cannot overwrite this file.
The following page links to this file:
Metadata
