File:Cnc wood lathe.jpg
Revision as of 00:14, 27 December 2019 by Eagletec (talk | contribs) (affordable cnc wood lathe machine)
Original file(900 × 527 pixels, file size: 82 KB, MIME type: image/jpeg)
Lathe Type CNC Lathe for Wood Control Mode 3-Axis CNC controlled Construction One rotary, two chisels, adjustable gymbal & electric spindle Electric Spindle for Broaching 3.5kw (4.7HP), air cooled, ER25 collet, variable rate 0 ~ 18000 RPM Headstock Driving Motor AC servo motor, 4.0kw (5.36HP) Rotary Feeding Range Variable from 0~3000 RPM Max. Simultaneous Axis Quantity Three (3 axis) Machining Capacity Turning, broaching, turn-broaching, embossment carving on column Lathe Controller Richauto DSP A132 (3 axis controller), read DXF file directly, USB interface Communication Code DXF, G code XYZ Motion Motor Stepper Driver YAKO YKA2811MA – 3PCS Y-Axis Feed Speed 47"/min (1,200mm/min) X Z Feeding Speed 19.6"/min (500mm/min) Wood Turning Blank Diameter Range 20mm ~ 300mm (From 0.78" to 11.81") Wood Turning Blank Length Range 100 ~ 1500mm (From 3.94" to 59") Tail Stock Air actuated tailstock Air Pressure Requirement 0.6~0.8 Mpa Inverter 2 PCS Working Volts AC380V, 3Ph 4 Wires / AC220V, 3Phase (make to order)
More details about this wood lathe machine, please clickAffordable CNC Wood Lathe Machine
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current00:06, 27 December 2019Thumbnail for version as of 00:06, 27 December 2019900 × 527 (82 KB)Eagletec (talk | contribs)cnc wood lathe machine
  • You cannot overwrite this file.
There are no pages that link to this file.
Metadata
