File:CompliantMechanismSheetmetal.zip
Revision as of 01:17, 31 May 2010 by MattMoses (talk | contribs) (Compliant mechanism 2D sheet metal pattern in svg, pdf, and dxf formats (all generated with InkScape))
CompliantMechanismSheetmetal.zip(file size: 11 KB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current01:17, 31 May 2010 (11 KB)MattMoses (talk | contribs)Compliant mechanism 2D sheet metal pattern in svg, pdf, and dxf formats (all generated with InkScape)
  • You cannot overwrite this file.
The following page links to this file:
