File:Convert crepes.zip
Revision as of 12:54, 2 April 2016 by PRZ (talk | contribs) (Small Libre office calc sheet. It converts G-codes according a given step/mm ratio of the first 8 notes of the children song 'Quand on fait des crêpes'. Use as a diagnostic/startup info for 'screenless' printers.)
Convert_crepes.zip(file size: 16 KB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current12:54, 2 April 2016 (16 KB)PRZ (talk | contribs)Small Libre office calc sheet. It converts G-codes according a given step/mm ratio of the first 8 notes of the children song 'Quand on fait des crêpes'. Use as a diagnostic/startup info for 'screenless' printers.
  • You cannot overwrite this file.
The following page links to this file:
