Revision as of 23:24, 15 November 2012 by Dazed.dnc (talk | contribs)
Original file(867 × 663 pixels, file size: 98 KB, MIME type: image/jpeg)
Ramps 1.4 diodes:
D1: Install this *ONLY* when using a 12V supply. This makes it possible to print without having the USB cable plugged in (Some additional hardware is required to run as a "stand alone" printer - such as SD ramps or an LCD controler)
D2: Appears to be part of a circuit to protect against reversed polarity. Even so, make a habit of checking the polarity. It is just smarter to not take chances.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current23:21, 15 November 2012Thumbnail for version as of 23:21, 15 November 2012867 × 663 (98 KB)Dazed.dnc (talk | contribs)
  • You cannot overwrite this file.
Metadata
