File:DarwinPartDevelopment-Diagonal-tie-bracket-1.1.stl
Revision as of 11:05, 20 January 2015 by Hari Seldon (talk | contribs)
DarwinPartDevelopment-Diagonal-tie-bracket-1.1.stl(file size: 564 KB, MIME type: unknown/unknown)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
Diagonal Tie Bracket designed to use no support material
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current13:09, 15 January 2008 (564 KB)VikOlliver (talk | contribs)Diagonal Tie Bracket designed to use no support material
  • You cannot overwrite this file.
The following page links to this file:
