File:HBC result1.jpg
Revision as of 00:33, 3 March 2014 by Repkid (talk | contribs) (The results of the heated build chamber. White part is with and red without. The red part is 10 by 10 cm and the white part is roughly 18 cm across.)
Original file(5,184 × 3,456 pixels, file size: 5.03 MB, MIME type: image/jpeg)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current00:33, 3 March 2014Thumbnail for version as of 00:33, 3 March 20145,184 × 3,456 (5.03 MB)Repkid (talk | contribs)The results of the heated build chamber. White part is with and red without. The red part is 10 by 10 cm and the white part is roughly 18 cm across.
  • You cannot overwrite this file.
The following page links to this file:
Metadata
