Revision as of 11:06, 24 April 2017 by Henri Starmans (talk | contribs) (Examples of lidar operations are everywhere; see http://www.renishaw.com/en/optical-encoders-and-lidar-scanning--39244 . Typically, the mirror rotates by rotating the housing. By tilting the mirror the scanning pitch can be changed. If a transparent po...)
Original file(492 × 836 pixels, file size: 37 KB, MIME type: image/png)
Examples of lidar operations are everywhere; see http://www.renishaw.com/en/optical-encoders-and-lidar-scanning--39244 . Typically, the mirror rotates by rotating the housing. By tilting the mirror the scanning pitch can be changed. If a transparent polygon is added. The vertical scan line could be increased and therewith the emission area.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current09:28, 28 April 2017Thumbnail for version as of 09:28, 28 April 2017492 × 836 (37 KB)Henri Starmans (talk | contribs)changed position polygon and therewith improved drawing a bit
11:06, 24 April 2017Thumbnail for version as of 11:06, 24 April 2017492 × 836 (38 KB)Henri Starmans (talk | contribs)Examples of lidar operations are everywhere; see http://www.renishaw.com/en/optical-encoders-and-lidar-scanning--39244 . Typically, the mirror rotates by rotating the housing. By tilting the mirror the scanning pitch can be changed. If a transparent po...
  • You cannot overwrite this file.
There are no pages that link to this file.
Metadata
