File:Lockblock.SLDPRT
Revision as of 17:39, 28 April 2011 by Bjs5286 (talk | contribs) (This is the Solidworks file for the "lockblock". This piece is "locked between 2 nylock nuts that are threded onto the main shaft (a 6/32 threaded rod).)
Lockblock.SLDPRT(file size: 142 KB, MIME type: /unknown)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current17:39, 28 April 2011 (142 KB)Bjs5286 (talk | contribs)This is the Solidworks file for the "lockblock". This piece is "locked between 2 nylock nuts that are threded onto the main shaft (a 6/32 threaded rod).
  • You cannot overwrite this file.
There are no pages that link to this file.
