File:Milling pcbs 06.jpg
Revision as of 07:38, 11 December 2010 by Lanthan (talk | contribs) (Example of pcb milling done on a tabletop cnc. 60 degrees cheap carbide v-bit with 0.2 mm flat end. Right: milled at 0.2 mm depth. Left: milled at 0.1 mm depth.)
Original file(1,200 × 829 pixels, file size: 240 KB, MIME type: image/jpeg)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current07:38, 11 December 2010Thumbnail for version as of 07:38, 11 December 20101,200 × 829 (240 KB)Lanthan (talk | contribs)Example of pcb milling done on a tabletop cnc. 60 degrees cheap carbide v-bit with 0.2 mm flat end. Right: milled at 0.2 mm depth. Left: milled at 0.1 mm depth.
  • You cannot overwrite this file.
The following 2 pages link to this file:
Metadata
