File:Mounting extruder gear with extra washers.png
Revision as of 06:29, 22 May 2011 by DeuxVis (talk | contribs) (Added some washers between the gear and the support so that the filament path is aligned with the filed and hobbed hole on the bolt.)
Original file(1,024 × 768 pixels, file size: 1.15 MB, MIME type: image/png)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current06:29, 22 May 2011Thumbnail for version as of 06:29, 22 May 20111,024 × 768 (1.15 MB)DeuxVis (talk | contribs)Added some washers between the gear and the support so that the filament path is aligned with the filed and hobbed hole on the bolt.
  • You cannot overwrite this file.
The following page links to this file:
Metadata
