File:Nuttblock2.SLDPRT
Revision as of 17:42, 28 April 2011 by Bjs5286 (talk | contribs) (This is the Solidworks file for the "nuttblock" into which 2 standard 6/32 nuts should fit. This should allow the threaded rod to slide though pushing or pulling on the lockblock oposite it.)
Nuttblock2.SLDPRT(file size: 204 KB, MIME type: /unknown)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current17:42, 28 April 2011 (204 KB)Bjs5286 (talk | contribs)This is the Solidworks file for the "nuttblock" into which 2 standard 6/32 nuts should fit. This should allow the threaded rod to slide though pushing or pulling on the lockblock oposite it.
  • You cannot overwrite this file.
There are no pages that link to this file.
